richard-g8jvm
Hi all,
first post , so no flames yet please
OS Linux Fed Fc17 , using Piklab 0.16 , but similar results on mplab.
I now have two bust ICD2 programmer/debuggers , from sivava.com
both have produced the same problem, when programming outa the blue when you have been using the same device, making changes to the code then trying it out, it will produce this message:-
Connecting ICD2 Programmer on USB Port with device 18F2550...
Firmware version is 1.4.5
Set target self powered: false
Connected.
Missing or incorrect device (Read id is 0x0000).
then no matter what I do, check cables, connectors, check the config in Piklab, even change the PIC, smd
I tried a few reloading the s/w with mplab on the first one and it hosed the bootloader.
So I purchased another, so I I found a fix I could at least put new firmware in, there are two PICs on this clone.
But now after a year or two s use its happened again,![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It reports the correct voltages on the target PIC, a PIC18F2550
The supplier does not answer any e-mail, so no help there.
Has anyone any suggestions on what causes this, or is it a cased of another programmer.
I'm in the middle of a project and now have a transceiver out of action as I cant control the DDS,
Richard
Connected.
Richard
