IF FOR loop problem getting my resistors burnt
ishtiaqshaheer
(I'm not very much good at coding)
When I'm using this Dimmer Code then its working fine even for a long time and nothing is getting burnt nor heated up.
when the code enters into if() loop only at that time my resistor burnt 2 times.
so it is due to zero cross detection isn't happening due to interrupts.(since onReceive() is an ISR & even dim_zero_crosss_int is also an ISR)
Thanks , I've uploaded programs as well as proteus circuits too.
Will be waiting for a solution
Thanks in advance
  • Programs & Proteus designs.zip
