If Statement in assembly (for PIC)
adrianvon
Hi all,
I have the following assembly program which is an ADC. It is monitoring the analogue input at AN0 and output its respective binary value to port D.
;REGISTER DECLERATIONS
REG1 EQU 60H ;;HEARE WE ARE NAMING THE GENERAL PURPOSE REGISTORS
ADC_H EQU 61H
ADC_L EQU 62H
COUNTER EQU 63H
ORG 0000H
	ORG 0004H
	ORG 00008H				;HIGH PRIORITY VECTOR
	ORG 000018H				;LOW PRIORITY INTERRUPT VECTOR
ORG 0020H
;ALL INTIALIZATION HERE OF ALL PORTS AND PERIPHERALS HERE
MOVLW B'00001110' ;;SET RAO AS AN0
MOVWF ADCON1
MOVLW B'00101100' ;LEFT JUSTIFIED
MOVWF ADCON2 ;;ACQUSITION TIME
				;;12TAD
				;;CLOCK FREQ FOSC/4
MOVLW B'00000001' ;;CHONNEL 0
MOVWF ADCON0 ;;ADC ON
MOVLW B'111'
MOVWF TRISE
MOVLW B'111111' ;;DECLARING PORT AS INPUT
MOVWF TRISA
CLRF PORTD
CLRF TRISD
;START MAIN PROGRAM HERE
MAIN
		CALL ACQ_DELAY ;CALL DELAY
		BSF ADCON0,1 ;SET ADCON0 bit 1 high
		LINE1
		BTFSC ADCON0,1 ;check if ADCON0 bit 1 if clear,if yes skip the next instruction
		BRA LINE1
		MOVFF ADRESH, ADC_H ;copying the value from ARESH into ADC_H
		MOVFF ADRESH, PORTD ;copying the value from ARESH into portD
		MOVFF ADRESL, ADC_L ;copying the value from ARESH into ADC_L
		GOTO MAIN
ACQ_DELAY
	MOVLW .3
	MOVWF COUNTER
	ACQ1
	DECFSZ COUNTER
	BRA ACQ1
	RETURN
Now i want to save the analogue input value to Register X, compare it to a value in register Y and if the value of Resister X is smaller, PORT B,0 will go to high, else it will remain low.
Can someone help me in doing this please.
BTW im using an 18F4550 PIC micro-controller.
Thanks in advance...
Check the PICList for all kinds of software routines (such as the conditional one you need), although it's mostly 16F series - but simple to convert for 18F.
You just use simple 18F assembler instructions such as this.
; to compare values
movf YVALUE, W
cpfseq XVALUE
goto notequal
; is equal so skip to here;
See the Intruction Set at the back of the 4550s datasheet for details of CPFSEQ
Is that code your own or some borrowed stuff, it looks rather hacked about and incomplete, are you trying to run it in a chip or simulator ?
Thanks for your reply Wp100.
Do i have to declare register W ?
I did the following coding where two switches are used to increment and decrement a value which is then saved in REG1 and the respective value is displayed at port D.
I also used your coding so that when the value in REG1 is greater than 00110000, an LED at port C,2 turns on, else it remains off.
REG1 EQU 60H
REG2 EQU 61H
REG3 EQU 62H
REG4 EQU 63H
REG5 EQU 64H
ORG 0000H
	ORG 0004H
ORG 0020H
MOVLW B'00000000'
MOVWF TRISD
MOVLW B'11111111'
MOVWF TRISB
MOVLW B'000000'
MOVWF TRISC
CLRF PORTD
MAIN
BTFSC PORTB,6
GOTO INC
LINE5
BTFSC PORTB,7
GOTO DEC
LINE6
MOVFF REG1, PORTD
MOVF B'00110000', W
CPFSGT REG1
BSF PORTC,2
BCF PORTC,2
BRA MAIN
INC
CALL DEBOUNCE_DELAY
INCF REG1
CALL DELAY
GOTO LINE5
DEC
CALL DEBOUNCE_DELAY
DECF REG1
CALL DELAY
GOTO LINE6
DEBOUNCE_DELAY
CLRF REG2
LINE1_DEBOUNCE_DELAY
DECFSZ REG2
BRA LINE1_DEBOUNCE_DELAY
RETURN
DELAY
CLRF REG3
CLRF REG4
MOVLW 15
MOVWF REG5
LINE1
DECFSZ REG3
BRA LINE1
DECFSZ REG4
BRA LINE1
DECFSZ REG5
BRA LINE1
RETURN
Now my problem is with the below coding since the LED at portC,2 is not working as expected...
MOVF B'00110000', W
CPFSGT REG1
BSF PORTC,2
BCF PORTC,2
If you can please help me in this i will appreciate it...
And by the way, i have seen the data sheet but i cannot understand it :( It gives an example (the one below) but i cannot understand what some of the statements are referring to (such as HERE) ??
Example: HERE CPFSGT REG, 0
NGREATER :
GREATER :
Before Instruction:
PC = Address (HERE)
W = ?
After Instruction:
If REG > W;
PC = Address (GREATER)
If REG ≤ W;
PC = Address (NGREATER)
The code was given to me by a lecturer and yes i am trying it on a chip.
The CPFSEQ instruction is similar to the BTFSS in that the instruction immediately following it should normally be a GOTO instruction.
You are simply setting that Port On then Off with the next instruction.
I would be interesting to see the whole code you have been given.
Without telling you all what needs doing all I can suggest is you follow a few tutorials in Assembler.
While the Beginners Sticky at the top of the forum suggests many assembler tutorial sites most are for the 16F range.
The 18Fs, though 90% similar, do have some important differences.
Have a look for 18F tutorials that may help you - here one, using the 4550.
https://www.pic18f.com/tutorial/2007/12/06/tutorial-2-hello-world/
Ok i managed to do it :) i used the following code:
MOVFF REG1, F
MOVLW .5
CPFSGT REG1
BSF PORTE,0
BCF PORTE,0
But i have another problem... the LED which is connected to PORTE,0 is very dim . I checked the output voltage and its showing olny 0.3V. I also changed to port and the same is happening.
Do you know what may be causing this problem please??
Think you have missed the point I mentioned - try this
	movlw	.5       ; load W with decimal 5
	cpfseq	REG1     ; compare the value in REG1 with the value in W  - if they are the same, skip the next instruction
	goto	unequal	 ; if they are not the same goto routine unequal
	bsf		PORTE,0	; they are equal so turn on port
					; REST OF THE CODE
unequal  bcf PORTE,0  ; turn off port
					; REST OF THE CODE
Before you can Output to PORTE,0 you must turn off its default Analogue setting and configure it as an Output - there is some example assembler code in the Datasheet in the PORT E section.
Yes i have set port E as output as shown in the coding below (in the INTIALIZATIONS section). [ MOVLW B'000' ....... MOVWF TRISE ]
REG1 EQU 60H
REG2 EQU 61H
REG3 EQU 62H
REG4 EQU 63H
REG5 EQU 64H
F EQU 65H
ORG 0000H
	ORG 0004H
ORG 0020H
;INTIALIZATIONS
MOVLW B'00000000'
MOVWF TRISD
MOVLW B'11111111'
MOVWF TRISB
MOVLW B'000'
MOVWF TRISE
CLRF PORTD
CLRF PORTE
MAIN
BTFSC PORTB,6
GOTO INC
LINE5
BTFSC PORTB,7
GOTO DEC
LINE6
MOVFF REG1, PORTD
MOVFF REG1, F
MOVLW .5
CPFSGT REG1
BSF PORTE,0
BCF PORTE,0
BRA MAIN
INC
CALL DEBOUNCE_DELAY
INCF REG1
CALL DELAY
GOTO LINE5
DEC
CALL DEBOUNCE_DELAY
DECF REG1
CALL DELAY
GOTO LINE6
DEBOUNCE_DELAY
CLRF REG2
DECFSZ REG2
RETURN
DELAY
CLRF REG3
CLRF REG4
MOVLW 15
MOVWF REG5
LINE1
DECFSZ REG3
BRA LINE1
DECFSZ REG4
BRA LINE1
DECFSZ REG5
BRA LINE1
RETURN
By the way im using CPFSGT not CPFSEQ.
Thanks in advance
OK, problem solved :)
The problem was that you cannot use BSF or BCF after CPFSGT, so i did the coding as the one below and it worked fine:
MOVFF REG1, F
MOVLW .5
CPFSGT REG1
GOTO LINE9
GOTO LINE8
LINE9
BSF PORTE,0
GOTO LINE7
LINE8
BCF PORTE,0
LINE7
Thanks alot for your help.
