IF statement in LTspice
Flyback
The attached doesnt work in changing the duty cycle. Do you know the syntax which will unlock the required action?
  • Duty cycle change1.asc
You are applying the "if" statement to a parameter during the simulation. Parameters MUST have an assigned value BEFORE the start of the simulation. You cannot use the if statement to change the value of a parameter during the simulation. You need to generate the changing duty cycle in another way.
A behavioral source might be the ticket.
