IF statement on LTspice
Firenze02
I would like to create a variable resistor as following:
R2=1 if i(R2)<1
R2=2 if 1<i(R2)<10
R2=3 if i(R2)>10
I know that the sintax is:
R=if(condition,valueiftrue,valueiffalse)
What about if I have three intervals?
The .asc file and the IF statement law is also shown in the attached files.
Which is the correct sintax to do that?
Thank you.
  • Draft2.asc
In theory, I think the nested IF expression R=if(i(R1)-9.5,3,if(i(R1)-0.5,2,1)) should give the three values to R. In practice, Spice doesn't like this because there is conflict at the 1A and 10A boundaries.
Consider a rising voltage from V1. As soon as 1A is reached, the resistance jumps from 1 to 2 Ohms, which immediately drops the current below 1A, so R jumps back to 1 Ohm. The outcome is the familiar "Time interval too short" message.
Someone else may know a work-around.
First I put the "if" inside the resistor. At 5mS the resistance changes
Next I found an example like this:
.param MODE 1
.param FREQ {if(MODE == 0, 1000, if(MODE == 1, 500, if(MODE == 2,250)))}
-----edited-----
I think this is what Alec_t said.
See this link: IF
R2=1 if i(R2)<1
R2=2 if 1<i(R2)<10
R2=3 if i(R2)>10
Thank you.
Hi again :)
See below.
In the .func statement, the "if" statement has to resolve to a number. I've added 0.5 at the end.
In the "Limit" statement, I've added arbitrary Min and Max values, 0.1,12, respectively. A discontinuity will occur if not used because at the start of the simulation R equals nothing (NaN). This will produce a "time step too small" error. The "Limit" statement will keep R2 equal to some value between 0.1 and 12.
eT
