This is on a Ford Zetec engine. There's a coil pack, with four HT leads and three LT connections. The coil pack is two double-ended coils as can be seen from the construction.
It's much like this:- https://www.ebay.co.uk/itm/316432985538 but it's made by NGK
The three LT connections are two primary coils of about 0.5 Ohms each and a common connection.
The HT connections for cylinders 1 and 4 have a resistance of about 8300 Ohms between them. The resistance between the HT connections for 2 and 3 is about the same.
That all seems fine. However, between the two HT coils there is a resistance of about 2.3 MOhm, which I'm fairly sure is wrong as it should be open circuit and indicates that there is a significant fault. There is no connection between the primaries and the secondaries.
Am I correct that there should be no connection at all between the two secondaries?
