Hi All,
I have been playing around with an Ignition system for a motorcycle that I am building in an attempt at a land speed record either this year or maybe next year..
I have attached several pictures & need some help with things--as usual!
First up I built a small test bed as shown, it has the flywheel generator at one end & is driven by a small universal ac brushed motor cooled by a microwave oven fan. I made a motor control circuit to vary the speed etc as shown.
(Yes, I have a cover for the bottom of the red switch so the connections are not bare as shown, thought I'd get in first as someone would have said something .
The drive motor is only 900W & is only capable of driving the generator to around 3500rpm--NO GOOD!
I then found a couple of other universal motors on some leaf blowers at the local tip, on the specification tags they are rated at 2400W.
I tested the current draw on the leaf blowers but they only draw around 4 Amps from the supply making them about 900W or so?
Shouldn't they draw 10 Amps making them 2400W or are they not loaded enough in the leaf blowers to draw this current?
Or are the manufactures misleading people?
If these motors are not suitable & to small which appears to be the case, what other motors can I use that I can control the speed of with my circuit used for the universal motors.
Can I use a 240v Induction Motor, the ones without the centrifigul switch or capacitor start?
Not sure about this or what types of motors I can control with my circuit, it's pretty basic?
The next thing is the CDI Ignition circuit.
My bike has a battery & a cdi ignition with an advance curve that is suitable for granny motoring to the shops & cannot be adjusted.
I need to discard the battery totally for weight reduction & have a CDI that will have some advance with no breaker points & no battery.
The circuit first:
The spark at the spark plug is not a solid single spark but a multitude of very fine sparks, a weak spark.
Could you have a look at the circuit attached & see where I can make some improvements in the output.
I have tried several capacitor values at C4 & C5 but it is best with the two cap values as shown at the moment.
I can only test to 3500rpm at the moment & at 3500 rpm the output from the gen coil-source coil loaded with the circuit, plug, coil etc is around 40v peak.
The bike will rev to about 8500rpm when finished & I am unsure what the gen output will be at that rpm until I can drive the test bed to that.
At lower rpm the spark plug still fires no problem but with several fine sparks instead of a single solid spark.
Maybe I need to rewind the Gen source coil for a higher output but I didn't want to do that until I can see what the output is at peak rpm now.
The circuit first:
