I have 4 round push button switches rated for 240VAC with an illuminated button rated at 24VDC. I will use the switches on 120VAC circuit and my problem is similar to this post
https://www.electro-tech-online.com/threads/illuminated-push-switch-problem.101729/
but his light is rated at 2.4VDC and the diode recommended is 1N4007, resistor 12k Ohms at 2.5 Watts or more.
I would like to know if I should use the same diode / resistor
