Impedance matching vs. balun
kellogs
As far as I can see around the internet, an impedance matching network, usually Pi, is present in radio designs. Mostly for unbalanced source and load (?).
But what about the case where there is a balanced source and unbalanced load ? To my nooby mind there ought to be one L or C series element at the source for cancelling its reactance followed by a lattice network balun for resistance transformation and nothing else. One can use a VNA to calculate both stages. Why am I not finding any such designs ?
Thank you
ugh, yes... let me rephrase what I would like to understand -
When a balun is required, for the sub-GHz ISM bands, the majority of application notes / other internet resources are talking about balun + impedance matching network (pi / tee / sometimes L). My question: why not balun + single reactive element that cancels source's reactance ?
Could it be because too high of a quality factor with only one such reactive element ?
The requirements depend on the type of antenna.
A half wave dipole, for a narrow frequency range, is easy to match. You can use a tuned length of coax, or a stub.
Examples:
A quarter wave vertical with radials can be end fed, it's about 36 Ohms with the radials horizontal - or pretty close to 50 Ohms with re radials angled down 45'
Broad band matching is slightly more complex, but still not all that difficult. A simple ferrite transformer is very effective at lower frequencies for both impedance and balance/unbalanced conversions.
