Get a panel with less voltage. Rewire yours for less voltage and higher current if you can. AndyMPPT can do the job but my cirucit is small-scale that a 6v solar panel charging a 1.2V battery
Thanks for ur all replies. I`d like to know how to measure the impedances of my source(solar panel) and load(battery). Should I use Smith chart or something else ? Is there any easiest way to do the job ? many thxxxxx
If you are hell bent on measuring the "impedance", just use a variable load resistance and measure the voltage and current as the load resistance varies.I`d like to know how to measure the impedances of my source(solar panel) and load(battery).
Rio FUN, I will give you a job any day, as my entertainments manager!Should I use Smith chart or something else ?
For best EFFICIENCY, the source impedance should be low compared with the load impedance.
Again, do some maths and you will see that for a matched load and source, for every watt supplied to the load, there is one watt dissipated in the source.
Not quite sure how this would work out with a solar cell, I guess it all depends on the ratings of the solar cell.Except you're not wanting maximum efficiency, you're wanting maximum power transfer
However, if you tried to put a "matched load" onto something like a car battery I think there would be a lot of sparks, a big bang and a shower of boiling sulphuric acid, as several kilowatts are dissipated in the battery.
But, as noted, you can't directly match the solar cell impedance to the battery impedance. You need some type of electronic power circuit in between. That circuit provides a matched load to the solar panel and converts the power to the correct level to charge the battery.
Hi all, I did some calculations and from the graph of volts/current obtained, it gave me the Maximum Power when 2.5V@10K ohms. I built a charge regulator which provide stable 1.44V charging voltage between solar panel and battery. Any suggestions on improving the efficiency?
Here is the circuit diagram. The solar panel is 6V@200mA and the data was measured when the solar panel was in the inside room instead of in full sunlight.
