Implementing ROM with Bus
EngIntoHW
Hey,
Could someone please explain how this bus is physically implemented?
In the below example, there's a 3-wire bus.
When, for example, address input is (0,0,0), then the output should be 1.
I don't understand how it works out.
Moreover, aren't these 8 AND gates supposed to be 'three-state' AND gates?
Meaning, each of them should have an Enable entry, that when zero, it outputs High-Z?
Thanks.
untitled-jpg.45705
The thick line represents 3 address wires.
Look at this image
EDIT:
I should add that the AND symbol is a complex AND function block and not just a 4 input AND.
You could image that the AND for ROM location '0' symbol represents say 3 inverters on the address line inputs which connect into a 4 input AND gate.
So when the 3 address lines are low and the Data bit is high the AND gate is enabled and the output onto the bus is '1'
Hey, thanks.
I understand how it logically works, but I dont understand how it physically works.
Could you draw it in more details?
Did my EDIT help to explain it OK.?
EDIT
Added image
Oh, so basically you implemented the ROM by a MUX, didn't you?
However, there's a conflict at the output, as I described in the attached image, isn't there?
The AND gates would normally be open collector outputs and the bus line would have single pull up resistor to +V.
So conflict, as I stated in the drawing they are not the actual IC's.
