What's the shape of an impulse?
Is it triangular, trapezoidal, rectangular, or none of these?
A lower height means a longer width to maintain the unit area. So that will depend upon the frequency response of the circuit you are applying the impulse to. The low frequency components of the pulse, as determined by its width, should be much less than the low frequency response of the circuit (so as far as the circuit response is concerned, it still likes like an impulse). This can be experimentally determined by increasing the pulse width until the output response of the circuit changes shape. You should maintain the width below that point.Hello,
I'm ok now with knowing that the area it covers is equal to one. This is consistent with crutschow's dirac delta function. However, I'm still wondering what is the lowest approximation we can give to the pulse height.
That's a good comment, since I think much of understanding technical stuff involves common sense (or logic to perhaps be more specific). Sometimes we ignore common sense since we think the subject is too complex to be understood by just analysis and logic. But I find it much better to intuitively (for lack of a better word) understand something then to try to use the equations that describe the subject, which generally leave me with no feeling for what's happening. Of course the equations are needed when we need to analytically calculate what's happening under specific conditions.Thank you very much. Another bunch of knowledge. I'm laughing at myself right now. Sometimes, I only need common sense.
