hi all
i'm trying to compile the following code in uVision3 and it's gives many error's!!!
error's:
test-5.asm(11): error A46: CODE-ADDRESS EXPECTED
test-5.asm(17): error A22: EXPRESSION TYPE DOES NOT MATCH INSTRUCTION
test-5.asm(91): error A45: UNDEFINED SYMBOL (PASS-2)
test-5.asm(386): error A9: SYNTAX ERROR
hope to get some help in ASM.
many thanks
ORG 0000H
AJMP MAIN ; go to main program
ORG 0003H
INT0OK:
MOV P0,#00H ; INT0 ISR routine for choosing the
JB 07H,INT00OK ; segment of display were we can
RETI ; change it
INT00OK:
AJMP INT0
ORG 0013H
JB 07H,INT1OK ; INT1 ISR routine for change the
CPL 02H ; the segment or
RETI ; or change the counter for up or
INT1OK:
PUSH A ; down countering
MOV P0,#00H
MOV A,R5
CJNE A,#00H,DD9
AJMP CHSEG0
DD9:
CJNE A,#01H,DD10
AJMP CHSEG1
DD10:
CJNE A,#02H,DD11
AJMP CHSEG2
DD11:
CJNE A,#03H,DD12
AJMP CHSEG3
DD12:
MOV R5,#00H
RETI
ORG 0080H
MAIN:
MOV IE,#85H ; start the main program
MOV TMOD,#25H ; timer 1=timer , timer0= counter
MOV DPTR,#0500H
MOV P3,#0FFH ; p3 as input
MOV R3,#00H
MOV R4,#00H
MOV R5,#00H
MOV R0,#00H
MOV R1,#00H
MOV R2,#00H
MOV P2,#11111110B
CLR 02H
CLR 07H
CLR 03H
SETB TR0 ; start timer 0 to sense for varying
MOV B,TL0 ; of input
MAIN2:
PUSH B
MOV A,R0
MOV B,R3 ; compare number with memory
CJNE A,B,S3
MOV A,R1
MOV B,R4
CJNE A,B,S3
CLR P2.1
JMP S4
S3:
SETB P2.1
S4:
POP B
MOV A,P3
JNB ACC.1,CHANGE ; sense for counter or change
CLR 07H
SETB P2.6
MOV R5,#00H
AJMP COUNTER
CHANGE:
MOV P2,#11111110B ; start change display program
CLR P2.6
SETB 07H
MOV A,R5
CJNE A,#00H,DD1
AJMP DISSEG0
DD1:
CJNE A,#01H,DD2
AJMP DISSEG1
DD2:
CJNE A,#02H,DD3
AJMP DISSEG2
DD3:
CJNE A,#03H,DD13
AJMP DISSEG3
DD13:
AJMP DISNUMBER
CHSEG0:
MOV A,R3
ANL A,#00001111B
CJNE A,#09H,DD4
MOV A,R3
ANL A,#11110000B
MOV R3,A
POP A
ACALL DELAY
RETI
DD4:
INC R3
POP A
ACALL DELAY
RETI
CHSEG1:
MOV A,R3
ANL A,#11110000B
CJNE A,#90H,DD5
MOV A,R3
ANL A,#00001111B
MOV R3,A
ACALL DELAY
POP A
RETI
DD5:
MOV A,R3
ADD A,#10H
MOV R3,A
ACALL DELAY
POP A
RETI
CHSEG2:
MOV A,R4
ANL A,#00001111B
CJNE A,#09H,DD6
MOV A,R4
ANL A,#11110000B
MOV R4,A
POP A
ACALL DELAY
RETI
DD6:
INC R4
POP A
ACALL DELAY
RETI
CHSEG3:
MOV A,R4
ANL A,#11110000B
CJNE A,#90H,DD7
MOV A,R4
ANL A,#00001111B
MOV R4,A
POP A
ACALL DELAY
RETI
DD7:
MOV A,R4
ADD A,#10H
MOV R4,A
POP A
ACALL DELAY
RETI
DISSEG0:
MOV A,R3 ; display segment 0
ANL A,#0FH
MOVC A,@A+DPTR
MOV P0,#00H
MOV P1,A
SETB P0.3
AJMP MAIN2
DISSEG1:
MOV A,R3 ; display segment 1
ANL A,#11110000B
SWAP A
MOV P0,#00H
MOVC A,@A+DPTR
MOV P1,A
SETB P0.2
AJMP MAIN2
DISSEG2:
MOV A,R4 ; display segment 2
ANL A,#0FH
MOV P0,#00H
MOVC A,@A+DPTR
MOV P1,A
SETB P0.1
AJMP MAIN2
DISSEG3:
MOV A,R4 ; display segment 3
ANL A,#0F0H
SWAP A
MOV P0,#00H
MOVC A,@A+DPTR
MOV P1,A
SETB P0.0
AJMP MAIN2
INT0:
PUSH A ; int0 for choosing segment number
ACALL DELAY
MOV A,R5
CJNE A,#03H,DD8
MOV R5,#00H
POP A
RETI
DD8:
ACALL DELAY
INC R5
POP A
RETI
COUNTER:
ACALL DISPLAY ; start counter program
AGIN:
MOV A,B
CJNE A,TL0,S
ACALL DISPLAY
AJMP MAIN2
S:
ACALL CUNTER
MOV B,TL0
ACALL DISPLAY
AJMP MAIN2
CUNTER:
JNB 02H,UC
SETB P2.3
MOV A,R0
ANL A,#0FH
CJNE A,#00H,Y1
MOV A,R0
ANL A,#11110000B
CJNE A,#00H,Y2
MOV R0,#99H
MOV A,R1
ANL A,#00001111B
CJNE A,#00H,Y3
MOV A,R1
ANL A,#11110000B
CJNE A,#00H,Y4
MOV R1,#99H
CLR P2.3
DEC R2
RET
Y1:
DEC R0
RET
Y2:
SWAP A
DEC A
SWAP A
ADD A,#09H
MOV R0,A
RET
Y3:
DEC R1
RET
Y4:
SWAP A
DEC A
SWAP A
ADD A,#09H
MOV R1,A
MOV R0,#00H
RET
UC:
SETB P2.2
MOV A,R0
ANL A,#00001111B
CJNE A,#09H,X1
MOV A,R0
ANL A,#11110000B
CJNE A,#90H,X2
MOV A,R1
ANL A,#00001111B
CJNE A,#09H,X3
MOV A,R1
ANL A,#11110000B
CJNE A,#90H,X4
SETB P2.1
INC R2
MOV R0,#00H
MOV R1,#00H
CLR P2.2
RET
X1:
INC R0
RET
X2:
SWAP A
ADD A,#01
SWAP A
MOV R0,A
RET
X3:
MOV R0,#00H
INC R1
RET
X4:
MOV R0,#00H
SWAP A
ADD A,#01H
SWAP A
MOV R1,A
RET
DISPLAY:
CJNE R2,#00H,NDZ ; start display program
AJMP DZ
NDZ:
MOV P0,#00H
ACALL DELAY
MOV A,R0
ANL A,#00001111B
MOVC A,@A+DPTR
MOV P1,A
SETB P0.3
ACALL DELAY
MOV A,R0
ANL A,#11110000B
SWAP A
MOVC A,@A+DPTR
MOV P0,#00H
SETB P0.2
MOV P1,A
ACALL DELAY
MOV A,R1
ANL A,#00001111B
MOVC A,@A+DPTR
MOV P0,#00H
MOV P1,A
SETB P0.1
ACALL DELAY
MOV A,R1
ANL A,#11110000B
SWAP A
MOVC A,@A+DPTR
MOV P1,A
MOV P0,#00H
SETB P0.0
ACALL DELAY
RET
DZ:
MOV A,R1
ANL A,#11110000B
CJNE A,#00H,DZ1
MOV A,R1
ANL A,#00001111B
CJNE A,#00H,DZ2
MOV A,R0
ANL A,#11110000B
CJNE A,#00H,DZ3
DD:
MOV A,R0
ANL A,#00001111B
MOV P0,#00H
MOVC A,@A+DPTR
SETB P0.3
MOV P1,A
ACALL DELAY
RET
DZ1:
SWAP A
MOV P0,#00H
MOVC A,@A+DPTR
SETB P0.0
MOV P1,A
ACALL DELAY
MOV A,R1
ANL A,#00001111B
DZ2:
MOVC A,@A+DPTR
MOV P0,#00H
SETB P0.1
MOV P1,A
ACALL DELAY
MOV A,R0
ANL A,#11110000B
DZ3:
SWAP A
MOVC A,@A+DPTR
MOV P0,#00H
SETB P0.2
MOV P1,A
ACALL DELAY
JMP DD
DELAY:
SETB TR1 ; start delay program
WAIT:
JNB TF1,WAIT ; use timer 1 for delay
CLR TR1
CLR TF1
RET
ORG 0500H
BD:
14,D7,4C,87
END
error's:
many thanks
