asp1987
I am trying to make an Inchworm programmer and would like to know if the circuit connections are proper. The resistance between the pins 16 n 15 of the MAX232 IC is only 650 ohms without inserting max232 and the PIC. These pins are connected to +Vcc and Ground of the PS circuit respectively. The circuit is not applied power. Also its not connected to the computer. I have already soldered the components on to a dot pcb.
Is that normal? Plz help.
