sorry if this sounds pretty dumb but...the assembly manual says that...
----The 16F877A “ICD2_BOOTLOADER_A.HEX” can be
downloaded from https://www.blueroomelectronics.com. If you bought just the PCB or damage the
16F877A you can order another preprogrammed one from one of the sources on the back cover of this
document or you could assemble a 16F877A programmer from one of the many designs you can find
searching the web. Searching the internet for “JDM PIC Programmer” should provide many results.
Note: If your Inchworm has a 16F877-20 the bootloader required is called “BL010101.HEX” and can
be found in your Microchip/MPLAB IDE/ICD2 directory when you install MPLAB.---
....does this mean that the inchworm can program ITSELF right from the start? from MPLAB? (i'm going to do my own pcb and buy the parts and build it myself so the 877 will be empty). Or do I still need another pic programmer irregardless of whether i use the 877 or 877A?
