Hi again,
I'll quote a couple of 'book' formul
Hi again,
I'll quote a couple of 'book' formulas here just for reference. The formula you posted does not look correct. Maybe you could quote what each variable is for, but as is it looks wrong.
Single Layer Cylindrical:
I=(R^2*N^2)/(9*R+10*L)
Multi-Layer Cylindrical (one of Wheeler's Formulas):
I=0.8*(R^2*N^2)/(6*R+9*L+10*B)
where
I is the inductance in microhenries,
R is the coil mean radius,
L is the length of the coil,
B is the build of the coil (multi layer),
and all length dimensions in inches.
I checked the second formula above by interpreting Bunet's formula and deriving a new formula based on his graph and associated sub formula, and the two formulas agree very very closely. Unfortunately, i can not find a reference for Bunet on the web anywhere. Perhaps it is time to add one
As Steve and myself have noted, these formulas and others like them (some decent ones on Wikipedia too) are approximations and should be taken only as a starting point for a design of a coil especially at higher frequencies.
To deal with the problem of inaccuracy build a coil and then provide a means for tuning. Since regular air core coils do not have a slug to slide in or out of the coil center, a common way to handle this is to design the coil so that it's inductance is too high and wind it on a coil form that is too long for the wire coil itself, then adjust the inductance by spreading the turns out slightly (which lowers the inductance) until the right value is attained. This is best done in the circuit it is going to be used for while it is running under normal operating conditions.
where
