Migrated from https://www.electro-tech-online.com/threads/pspice-to-ltspice-igbt-model.121631/
Hello,
I know that this post is quite old but is describes also my current problems.
I'm also trying to implement an Infineon IGBT into my LTSpice. It has the .subckt statement.
On the infineon page is the file which I'm using (the fist one):
https://www.infineon.com/cms/en/search.html#!view=all&term=igbt simulation model spice&area=downloads
I used the NIGBT inside the standard library and changed the the prefix to x and the value to IKW40N65H5A_L2.
Then I changed the name of the .lib file to IKW40N65H5A_L2.txt and copied it to the directory in which my schematics are.
My last step the was the SPICE directive : .inc IKW40N65H5A_L2.txt
When I start the simlation, I get the following error:
Unknown subcircuit called in: xu1 drain gate source IKW40N65H5A_L2
Could someone help me?
Hello,
