infrared Liquid level detector-SharpGP2D12
Infrared liquid level detector
specifications of design:
The design should be useful in liquid level or proximity detection. It should operate by detecting the distance from the target by reflection of an infra-red beam. It should safely detect the level of a liquid in a tank without any contact with the liquid itself. The device's range should be variable, from a couple of cm. to about 50 cm.
It is a continuous liquid level detector.
I must be able to display the results on an LCD screen.
ie. The level of the liquid in cm
tank empty
tank full
error message etc
The device should also be reconfigurable and able to work on any tank
I went to Nigels page to just check out how to interface the GP2D12 to a micro but when i click the tutorial nothing comes up...
There's a project on this page that uses the Sharp GP2 sensor;
Connect JuneBug to serial port and Sharp GP2 sensor
(see project 4)
It is in C, and has some very simple refined math for converting the logarithmic sensor output to linear range reading in cm (or inches).
lol OMG i didnt realise that you are the MAN himself. RB-Roman Black:eek: Pleasure to meet you.
Any idea how well the sensor works with condensation on either lens?
Can the sensor measure the level of water in a vessel, or does it need a colored surface?
hi bryan,
In another thread by the OP, he states that the liquid dosnt have to be water, he can choose the liquid.
I also raised the point about poor reflection from clear water
I tested the GP2 sensor last night. I entered values of Analogue output Voltage Vs distance(cm) into a table in Excel and plotted its relationship.....The shape is similar to that of the datasheet for the sensor....So the sensor does work on liquids. Ill attach the graphs onto this thread sometime when im home....
Im programming in C, using MPLAB IDE Hi-Tech universal toolsuite ANSi C compiler....
Now i need to program the PIC16f690 to manipulate the output of the sensor and give me continuous measurements in cm of a (varying) liquid level in a container....MR RB has been very kind and directed me to his project page which basically does what i need my sensor to do...but he uses the junebug 18F1320.....
I dont need to send that data as a text string to PC(for now maybe i could add it later) because im using a LCD to display the measurements....
Now there are differences with the PIC16f690 and 18F1320:confused: and im a beginner...and tend to get lost along the way......
/*  Junebug_Serial4.c    RomanBlack.com 19th July 2009.
	Junebug 18F1320, uses my "zero error 1 second timer"
	system to generate a 2 second interval, then every
	2 seconds it reads an analog voltage from a
	Sharp GP2 distance sensor and converts it to decimal
	distance, then sends that data as a text string to PC
	via bitbanged serial out. It also flashes Junebug LED1
	everytime it takes a distance sample.
	Code for MikroC, config handled by MikroC compiler;
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
// functions declared
void calc_distance(void);
void send_serial_message(void);
void send_serial_byte(unsigned char);
#define PIN_SER_OUT LATA.F3		// which pin for serial out (PORTA.F3)
#define SER_BAUD 51				// TMR3 (1Mhz/19200 baud) = 52
								// tested; works from 49 to 53, using 51
unsigned char i;		// used for looping
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned long bres;		// for bresenham 2-second timer system
void main()
	// setup the PIC 18F1320
	OSCCON = 0x72;      	// internal osc, 8MHz
	PORTA = 0;
	[COLOR="Red"]TRISA = 0b10000010; 	// RA7 high imp, RA3 is serial out,
							// RA1 is [/COLOR]ADC input measuring VR1
	PORTB = 0;
	INTCON2 = 0;            // PORTB pullups ON
	TRISB = 0b00000000; 	// PORTB not used
	ADCON0 = 0b00000101;	// ADC ON, RA1 is ADC input
	ADCON1 = 0b01111101;	// AN1 is ADC input
	[COLOR="RoyalBlue"]ADCON2 = 0b10100010;	// right justify, 8Tad, 32Tosc[/COLOR]
	T1CON = 0b00010001;     // TMR1 is ON, 1:2 prescale, =1MHz
	T3CON = 0b00010001;     // TMR3 is ON, 1:2 prescale, =1MHz
	// main loop here;
	while(1)
		// wait for 2 seconds, uses TMR1 free running at 1Mhz
		while(!PIR1.TMR1IF);    // wait for TMR1 overflow
        PIR1.TMR1IF = 0;		// clear overflow flag
		LATA = 0;				// all LEDs off
		bres += 65536;			// add 65536uS to bres value
		if(bres >= 2000000)		// if reached 2 seconds!
			bres -= 2000000;	// subtract 2 seconds, keep error
			// flash Junebug LED1,  RA0=1 RA6=0 RA7=hiimpedance
			LATA.F0 = 1;			// LED on
		    // read the ADC voltage RA1 (Sharp GP2 sensor)
		    ADCON0.F1 = 1;		// set GO bit, start doing ADC
		    while(ADCON0.F1);	// wait until ADC done
			calc_distance();		// convert ADC value to distance
			send_serial_message();	// send message back to PC!
	// from the Sharp datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the sensor
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	// send message and number to serial port
	send_serial_byte('J');			// send ascii text
	send_serial_byte('u');
	send_serial_byte('n');
	send_serial_byte('e');
	send_serial_byte('b');
	send_serial_byte('g');
	send_serial_byte(' ');
	send_serial_byte('G');
	send_serial_byte('P');
	send_serial_byte('2');
	send_serial_byte('=');
	send_serial_byte('0'+ cm10);	// send number as ascii text 0-9
	send_serial_byte('0'+ cm);	// send number as ascii text 0-9
	send_serial_byte('c');
	send_serial_byte('m');
	send_serial_byte(13);			// send carriage return/linefeed pair
	send_serial_byte(10);			//  to start a new text line
void send_serial_byte(unsigned char data)
	// this manually sends a serial byte out any PIC pin.
	// NOTE! serial is inverted to connect direct to PC serial port.
	// baud timing is done by using TMR3L and removing
	// timer error after each baud.
	i=8;						// 8 data bits to send
	PIN_SER_OUT = 1;			// make start bit
	TMR3L = (256 - SER_BAUD);	// load TMR3 value for first baud;
	while(TMR3L.F7);			// wait for baud
	while(i)			// send 8 serial bits, LSB first
		if(data.F0) PIN_SER_OUT = 0;    // invert and send data bit
		else		PIN_SER_OUT = 1;
		data = (data >> 1);			// rotate right to get next bit
		i--;
		TMR3L -= SER_BAUD;      // load corrected baud value
	PIN_SER_OUT = 0;		// make stop bit
	TMR3L -= SER_BAUD;		// wait a couple of baud for safety
	while(TMR3L.F7);
	TMR3L -= SER_BAUD;
	while(TMR3L.F7);
I highlighted the 3 lines im getting confused with....
[COLOR="Red"]
			// RA1 is [/COLOR]
Question1:The 16f690 doesnt have a RA7. What does makin the pin a high impedance mean? Im assuming imp is impedance. I know TRIS sets pins as inputs and outputs.
Question2:
I dont know how to set 8Tad on the 16f690. Could someone please tell me how to do that? I looked at the datasheets and i couldnt see any bit in a register that does sets it.....
Question3:
Does analogue channel select bits bits5-2 0001=AN1 mean that AN1 is ADC input?
Well for now thats giving me trouble...so if any1 knows....Please help me out...Thanks...
This was just a rough test i did with the GP2 and various liquids....
tomorrow i plan to do a more accurate test so each liquid will have the same type of container
  • comparison of all charts.doc
Yeah your chart shows a couple of funky readings (obvious on that milk reading that jumps about).
I have used 3 types of the Sharp GP2 sensors with no real stability problems but I had a good +5v supply and short wiring. Lots of people do report erratic readings, (probably noise?). Putting a 10uF cap right at the sensor power between +5v and ground is supposed to help, and also doing some low pass filtering of the analog voltage out would help especially if you have long wires between the sensor and the PIC.
All I did was try doing a single ADC reading, then tried using multiple readings averaged. There was never much discernable difference between the 2 systems and my readings were stable whenever there was no movement of sensor or target. So that was good enough for me.
I'd love to see your results with different liquids AND different heights of liquid to see if there is a back reflaction from the bottom of the container.
And why use a look up table to correct the nonlinearity?? My version of the Sharp formula dist = (1 / volts)+n worked really nice. I think lookup tables are another reason people get jumpy values, (unless they are using a 1024 entry table).
Hello Mr RB.....I manually took the readings with a tape measure...i never implement your code yet.....And thanks for the advice.......
My wires are LoooonG...ill shorten them and ad that capacitor and LPF...
Here are more new measurements i HAD taken b4 reading your advice( so these readings dont have a capacitor or LPF or short wires)............See the attached document.............this was not rushed; i measured it pretty accurately...
Taking these readings are time consuming:eek:.....
But i have to redo them with short wires...etc. At least ill have more to talk about in my demonstration to my lecturer(or ill reach that 50 page requirement for my report submission lol-just looking on the bright side of taking another 40 readings:))
I dont plan on using a look up table any more.....i think your method is much better....Mr RB.
Well ill try and take the new readings later tonight....i have to prepare a presentation on JOSEPHSON junctions and what they good for...My turn is on tuesday so i better make a start with that.....
  • graphs.doc
Good afternoon.
Interesting data. I am not so worried about the quantitative differences, but the qualitative difference (i.e., the dip at distances <10 cm) with milk and not with water/oil/red wine needs some more thought.
We are concerned about reflection from surfaces or interfaces other than the liquid's top surface. Just a short digression... In analytical science, one must show that the response is actually due the the analyte, not just proportional to it. As a trivial example, assume you have a substance, "A" that has a little impurity, "B" in it. So, you develop an assay that correlates perfectly with A. Problem is, your assay actually measured B, but because the ratio was constant, it correlated with A very well. If you were to put that assay into practice, a different batch of material will likely have a different ratio of A and B and your assay will not give accurate results for A with other batches of material. Believe it or not, I have seen real life examples of that error.
In your case, you need to show that the reflective surface being measured is the air-liquid interface ("A" in the above example), not some other surface ("B" in the example).
1) When you do these experiments, do you have a stable way to position the detector, like a ring stand and clamps, or is it just being hand held?
2) What are the dimensions of your liquid container(s)? Is your detector situated over the center or near an edge? Do your results vary if you move the detector off center? I looked briefly at the datasheet and suspect you may be able to move one direction, but not the other, without an effect from the edge of the container.
3) The experiment I suggested earlier was designed to detect secondary reflections that might influence your results. In other words, at a set distance from the liquid's surface, the value you get should be exactly the same (within experimental error) regardless of the depth of the liquid. A water depth of 1 to 2 cm was chosen, as that would allow a significant percentage of your IR light to penetrate to the wall. I have no idea about the IR transmissivity of milk or wine. I suspect wine may be nearly as transparent as
water at 940nm; purified mineral oil (mineral, not vegetable) certainly is as transparent or more so. The fact that the three liquids gave identical results is consistent with that. Vegetable oil may also be pretty clear too.
4) What was the "green" solution? Was it green-tinted water? Is it colored with a dye or a pigment?
I have to get the morning shopping done. It is a little after 0800 where I am. Sorry about the lengthy response. It is great to see someone on these forums who is willing to put forth the effort and is not just an "I want the answer type." If I seem picky, it is because most of my career entailed designing analyses and making decisions based on the results.
John
1)do you have a stable way to position the detector, like a ring stand and clamps, or is it just being hand held?
The sensor has holes, i fastened one side of it with a nut and bolt....its at the edge of my breadboard. Its fixed...
Im using a glass tumbler...it has a bluish tint. I positioned the tumbler so that the detector is over the centre.....(i used a plumb bob to verify this)
Its hehe dish washing liquid...pretty thick
:rolleyes::rolleyes::rolleyes:
Why thanks...
I'll answer the rest of your questions when i take new readings later....im half way done with my presentation for superconductivity..:)
MR RB
What RC values would you recommend me using?
hi Miss Fantabulous,
Its refreshing to see someone putting the time, effort and detail into their project as you are obviously doing.
I'm sure most of the older members of this Forum feel the same way as I do, well done, you deserve every success with the project.:)
I think 1) might be an issue especially up close if the sensor is at a different angle to the liquid surface the close readings will vary. There's still too much variation in the different charts for my liking, as IF the Sharp sensor is measuring the surface reflection properly then the weird rises/dips in the charts just won't happen. So it is either not reading the surface refection properly or there are errors in position and angle.
For 2) the problem with a liquid depth of 1 to 2 cm is that the sensor might just have been measuring the bottom of the container. That's why I said to the OP before it really needs some testing of the same surface distances, but with varying liquid depths, to test if there is any effect of change in depth and that it is always measuring the surface reflection only.
Fantabulous-
A 10uF cap right at the sensor between +5v and ground (tantalum is good). For the low pass filter it is not critical, the Sharp sensor takes one reading every 40mS so you can just put a large (0.1uF ?) cap on the ADC input pin and rely on the Sharp output circuit having some impedance so you don't need a series resistor. If this is eventually used for liquid measuring in a tank you could go for a much larger cap as the liquid level will never change that fast and the more filtering the better.
Very nice. I love experimentation. Did you vary the depth of the liquid or just the distance from the liquid's surface? The experiment I would sugest is water in a deep bowl. Add about 3 to 4 cm of water and measure at 10 and 20 cm from the surface. Then increase depth of water 10 cm and repeat.
John
Edit: On reconsideration, make the initial water depth only 2 to 3 cm. Keep the rest the same.
Ok all the previous measurements were me varying the distance of the container to the sensor...........
But now i am varying the level of the liquid in the container...........................
I varied the level of water in a glass and plastic vessel......see the attached doc...
I will take more readings when i get time, will take readings at 2 10 20 ....80 for various liquids...got to finish up my presentation
hi Miss Fantabulous
hehe Hi Mr Ericgibbs you got it right this time. Thanks
  • water,plastic,glass.doc
