Inline function question
electroRF
Hi guys,
I have a question please.
Say that you define an Inline Function in an H File.
e.g.
C:
__inline unsigned int returnMax(int a, int b)
     if (a > b)
          return a;
      return b;
If no one calls this function, will it occupy zero memory?
If the Inline Function was defined as Static Inline, e.g.:
C:
static __inline unsigned int returnMax(int a, int b)
     if (a > b)
          return a;
      return b;
Will it still occupy Zero Memory if no one calls it?
I'm using GNU Compiler.
Thank you.
Compiler to compiler!!!!
The first one shouldn't be compiled, dependent on optimization..
The second shouldn't also, dependent on optimization..
Using volatile it will always be compiled..
C:
volatile __inline unsigned int returnMax(int a, int b)
     if (a > b)
          return a;
      return b;
Thank you folks!
NG
What do you mean please by ignore it?
Inline tells the compiler to "copy paste" the function's code to where the Caller calls it.
You need to get to grips with YOUR compiler.... Try writing a section of code... Use variables and functions that are/ aren't used variables that are initialized but unused... Compile with differing levels of optimization and you'll soon see what is compiled and what isn't..
You give the compiler a hint. Whether it takes it or not is up to the compiler.
BTW: inlining is more compilcated than copy/paste.
