I have a generator that supplies power to 3 battery chargers, one is solid state, one is a mag resonance charger and the other is a simple transformer type with rectifiers. 120v AC in and 14.4v DC out.
When I start the engine while the generator is running the instruments get fried and I was wondering if any of the chargers were producing some form of spike caused by the starting load of the engine.
The circuit that gets fried is a quad OP295 op amp that has its power supply direct on the 12v line out from the batteries.
The main reason this is serious is because we are just about to fit a unit that draws around 600 amps and may be used up to 10 or 20 times for about 5 seconds at a time in a window of say 5 minutes. This kind of load on the batteries requires the chargers are all running to keep the volts up but will most likely fry the instruments again. OR worse it could fry other more expensive stuff.
So does any one have any ideas as to what may be happening, can spikes occur?
Many thanks
Quantised
Many thanks
Quantised
