Interfacing I2C IC with Proton Developement Board V1.0
Tamil.selvam
Hi all.....I'm trying to interface an 8-bit ADC circuit to a proton development board via a I2C IC (PCF 8574P)....but all i'm getting on the LCD is 11111111 regardless of what the input is....i know for certain that the ADC works as i'm getting the correct value on the LCD when i connect the ADC directly to the proton board....i've checked to make sure the all appropriate pins have been grounded.....the proton board uses a 16F877A Pic....does anyone have any suggestions? thank you for your time.
regards
Tamil
Hi Steve....here is my code....
Device 16F877A
XTAL = 20
ALL_DIGITAL = True
Declare SDA_PORT PORTC.4
Declare SCL_PORT PORTC.3
Declare HBUS_BITRATE 100
Dim ADC_Data As Byte
LCD_DTPIN = PORTD.4
LCD_ENPIN = PORTE.1
LCD_RSPIN = PORTE.0
LCD_LINES = 2
Main:
HBStart
HBusOut %01000100
If SSPCON2.6 = %1 Then
Cls
Print "No Ack"
DelayMS 3000
Else
ADC_Data = HBusIn
Cls
Print Dec ADC_Data
DelayMS 1000
End If
HBStop
GoTo Main
End sub
regards
Tamil
i think you need to examine your handshaking a bit
try using the high level i2c commands first, hbusin addr, loc, [data] ... and then try the low level
if I recall, a read happens like this
start
write device address R/w = w
write memory address
restart
write device address R/w = R
read
ack or stop
