Internal Clock and output frequency
chopnhack
Hello all, I am investigating the use of a PIC12F675 to produce various frequencies on one of its GPIO's. I am aware and have experimentally confirmed that the INTRCCLK will output a ~1MHz signal on pin 3. I wanted to see if I could get a range of frequencies by simply toggling a port on and off. I got some unusual results that I wanted to see if anyone knows why they would occur. It seems as if there is a ceiling of ~187KHz. Results are in the table below:
XTAL 40000001ms1.1KHz
0.1ms9.69KHz
0.01ms64.2KHz
0.001ms158KHz
XTAL 80000000.001ms136.8KHz
XTAL 10000000.01ms187KHz
XTAL 5000000.1ms58KHz
0.01ms158KHz
0.001ms187KHz
The code used is below, the define _XTAL_FREQ line was changed for each set of runs:
C:
// CONFIG
#pragma config FOSC = INTRCCLK  // Oscillator Selection bits (INTOSC oscillator: CLKOUT function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-Up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = ON       // GP3/MCLR pin function select (GP3/MCLR pin function is MCLR)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#include <xc.h>
#define _XTAL_FREQ 500000
 void main (void)
  // SET UP
  TRISIO = 0b000010;          //Only AN1 is a input all else are outputs.
  while(1){
      GPIO = 0b000000;        //Off
      //__delay_ms(1);
      GPIO = 0b100000;        //GP5 On
      __delay_ms(0.001);
The scaling from 1ms to 0.1ms is nearly perfect with 4MHz intrcckl - 1 to almost 10KHz, but it seems to fall off from there. Any thoughts? Thank you all in advance.
