interrupt code not being complied in Arduino IDE
Sashvat
hi guys, I was learning how to use interrupts on Arduino and saw this tutorial -
I wrote the code and when I compiled it the IDE didn't and had an error message saying "buttonPressed was not declared in this scope". What have I done and what is wrong with this code? I have attached the file I have written here, please let me know.
thank you
  • interrupts_2.ino
You can't put your routine inside the main loop - move it outside and it compiles OK.
C++:
volatile boolean ledOn = false;
void setup() {
  // put your setup code here, to run once:
pinMode(13, OUTPUT);
pinMode(2, INPUT);
attachInterrupt(0,buttonPressed,RISING);
void loop() {
  // put your main code here, to run repeatedly:
void buttonPressed(){
  if(ledOn){
    ledOn = false;
    digitalWrite(13, LOW);
  }else{
    ledOn = true;
    digitalWrite(13, HIGH);
C++:
void setup() {
pinMode(2, INPUT);
void loop() {
  if(ledOn){
    ledOn = false;
  }else{
    ledOn = true;
Thank you very much finally got it
