Interrupt for UART via MikroC
Vizier87
Active Member
Hi guys,
I've started with configuring a lot of functions with my newly built remote which consists of keypads and an Xbee module with a 877A.
My transmitter goes on like this:
C:
 if (plus==1){
       txreg=0xbf;
     if (Enter==1){
       txreg=0xca;
     else txreg=0;
I've successfully received data at my receiver, a 18F4620, in which I only did it like this:
C:
if (rcif==1){
  portd=rcreg;
And portd lights up accordingly.
However, if I try to perform more actions within a certain value of the rcreg, like this:
C:
if (rcreg==0xAA){
  portd=~portd;
  Delay_ms(1000);
So basically, I'd like to make the receiver blink as long as it's receiving data. Now, that didn't work smoothly. Always I get it without getting out of the loop when my transmitter is not transmitting anything.
So my friend told me I need to use interrupt on this one. The thing is, I just don't know how to use it for this purpose. I still don't understand interrupts on this case.
Hope anyone can give me an example.
Thanks.
Vizier87
You use a timer and let it tick off the delay and set event to toggle the portd
Have a look at this **broken link removed**
I don't what happen here two post for one lol
Thanks Burt.
you see, it's not only just toggling pins or anything like that. It's just that I need it to perform a function as long as a data is received. It has a sort of a discontinuity of the data when I measured the output at a scope.
Let's say I send 0xAE.
So receiver program:
C:
 if (rcif==1){
   buffer=rcreg;
     if (buffer==0xAE){
        rd5_bit=1;
  else rd5_bit=0;
I'm not sure if that's the right way to do it though. Any corrections?
So anyway, when I measure the data using a scope, as long as I'm pushing the button which sends the data 0xAE, the received data is not continuous at all. There is a PWM effect, and the LED lights up dimly.
Thanks for the help.
Vizier87
