interrupt on pic16f689
maryem
Hello ,
I'm doing a program on MicroC using push buttons and switches
but the problem with the change interruption on porta doesn'twork,
C:
void interrupt (void){
  unsigned char dummy;
if ((INTCON.RABIF==1) && (PORTA.F0==1) && (INTCON.RABIE==1) )
         PORTC.F3 = 1;
           PORTC.F4 = 0;
         dummy = PORTA;     /// <- HERE!!!
         dummy = PORTB;     /// <- AND HERE!!!
         INTCON.RABIF =0 ;
         Delay_ms(500);
         PORTC.F3 = 0;
           PORTC.F4 = 0;
void main() {
ANSEL = ANSELH = 0;                   //all pins I/o are cofigurred as digital
C1ON_bit = C2ON_bit = 0;              //Désactivation de deux comparateurs
INTCON.GIE =1 ;                         // Gener al interrupt enabled
INTCON.RABIE=1 ;
INTCON.RABIF=0 ;
IOCA = 1 ;                            //     PORTA cause an interrupt on lofic state change
IOCB = 1;
TRISA=1;                              // PortA  input
TRISB=0b00010000;                     //RB4 input , others output
TRISC=0b00000111 ;                     //portC RC0,RC1,RC2 input , others output
PORTC.F6=0;
PORTC.F7=0;
PORTC.F4=0;
PORTC.F3=0;
do {
if (PORTA.F0==1)  {
PORTC.F3=1;
PORTC.F4=0 ;
    else if (PORTA.F1==1)  {
PORTC.F3=0;
PORTC.F4=1 ;
}while (1);
You have set IOCA to 1 and IOCB to 1?? Is this where your inputs are? According to the portb rem statement you are using RB4 as input... That means IOCB should be 0x10 ( ooo1oooo)..
Don't know about porta as you haven't specified..
thank you , i will try , the interruption is activated by changing in PORTA(pin 0 and 1 ) and PORTB (pin 4)
