I'm currently having problems setting up an interrupt in my c code - this is the first time i have used interrupts and am having difficulty understanding where i'm going wrong....
In my initialise function i set up the interrupt bits:
Outside of the main, my ISR consists of:
My code builds successfully but in MPLAB SIM I get the error message:
CORE-E0001: Stack over flow error occurred from instruction at 0x0000d8
Is this because i'm trying to call a function within the interrupt? Have i set up the interrupt bits correctly?
Help on this would be greatly appreciated, as i'm very confused!
Thanks in advance,
elec123
OPTION = 0x00;
INTCON = 0x00;
OPTION = 0x02;
GIE = 1;
PEIE = 1;
TMR0IE = 1;
TMR0 = 0x82;
void interrupt_isr()
unsigned char dig_output;
// Output error voltage correction
ADCON0 = 0x88;
a2d_conversion();
dig_output = ADRESH;
if (dig_output<97) // output voltage is less than 99V
--bodge; // increment duty cycle
else if (dig_output>100) // output voltage is greater then 101V
++bodge; // decrement duty cycle
TMR0 = 0x82;
TMR0IF = 0;
Thanks in advance,
elec123
