interrupt problems with button
matlark
Hello,
I cannot get the interrupt to work correctly on the following code. Can anybody see what I am doing wrong?
cblock 0x20
Delay1 ; Assign an address to label Delay1
Delay2
Display ; define a variable to hold the diplay
Direction
LookingFor
temp1
die1
temp2
die2
endc
cblock 0x70
W_Save
STATUS_Save
endc
org 0
goto Start
org 0x004 ; interrupt vector location
Init:
clrf PORTA ; Clears memory in file register A
clrf PORTB ; Clears memory in file register B
clrf PORTC ; Clears memory in file register C
clrf PORTD ; Clears memory in file register D
clrf PORTE ; Clears memory in file register E
bsf STATUS,RP0 ; select Register Bank
bsf IOCB,0
movlw 0x01
movwf TRISB ; Make RB0 input
clrf TRISD ; Make PortD all output
movlw b'10010000'
movwf INTCON
movlw b'00000111'
movwf OPTION_REG ; Maximum Prescale
bcf STATUS,RP0 ; back to Register Bank 0
return
ISR:
movwf W_Save ; Save context
movf STATUS,w
movwf STATUS_Save
btfsc INTCON,INTE
goto DieNumSel
goto ExitISR
DieNumSel:
movf TMR0,w ;grabs a value from TMR0 and stores in working reg.
movwf temp1 ;moves working reg to file temp1.
andlw b'00000111' ;Ands literal 00000111 to working reg
call Tabledie1 ;calls tabledie1
movwf die1 ;moves result of working to file die1
btfsc die1,7 ;tests msb, if 1 go back to beginning to ensure no 1 in msb.
goto DieNumSel
movf temp1,w
swapf temp1,w
andlw b'00000111'
call Tabledie2
movwf die2
btfsc die2,7
goto DieNumSel
;swapf die2
;movf die1,w
addwf die1,w
movwf PORTD
goto $
Tabledie1:
addwf PCL,f ;jump to
retlw b'10000000'
retlw b'00000001'
retlw b'00000010'
retlw b'00000011'
retlw b'00000100'
retlw b'00000101'
retlw b'00000110'
retlw b'10000111'
Tabledie2:
retlw b'10000000'
retlw b'00000001'
retlw b'00000010'
retlw b'00000011'
retlw b'00000100'
retlw b'00000101'
retlw b'00000110'
retlw b'10000111'
ExitISR:
movf STATUS_Save,w ; Restore context
movwf STATUS
swapf W_Save,f ; swapf doesn't affect Status bits, but MOVF would
swapf W_Save,w
retfie
Start:
call Init
rotate:
end
Doesnt this look way better?
	cblock 0x20
	Delay2
	Direction
	LookingFor
	temp1
	die1
	temp2
	die2
	endc
	cblock 0x70
	W_Save
	STATUS_Save
	endc
org 0x00
goto Start
goto ISR
Init:
	bsf IOCB,0
	movlw 0x01
	movlw b'10010000'
	movwf INTCON
	movlw b'00000111'
	return
ISR:
	movf STATUS,w
	movwf STATUS_Save
	btfsc INTCON,INTE
	goto DieNumSel
	goto ExitISR
DieNumSel:
	goto DieNumSel
	movf temp1,w
	swapf temp1,w
	andlw b'00000111'
	call Tabledie2
	movwf die2
	btfsc die2,7
	goto DieNumSel
	;swapf die2
	;movf die1,w
	addwf die1,w
	movwf PORTD
	goto $
Tabledie1:
	retlw b'10000000'
	retlw b'00000001'
	retlw b'00000010'
	retlw b'00000011'
	retlw b'00000100'
	retlw b'00000101'
	retlw b'00000110'
	retlw b'10000111'
Tabledie2:
	retlw b'10000000'
	retlw b'00000001'
	retlw b'00000010'
	retlw b'00000011'
	retlw b'00000100'
	retlw b'00000101'
	retlw b'00000110'
	retlw b'10000111'
ExitISR:
	movwf STATUS
	swapf W_Save,w
	retfie
Start:
	call Init
rotate:
end
btfsc INTCON,INTE
This just test if the interrupt is enabled and not if the flag bit is set...
What are you trying to do?
REGISTER 2-3: INTCON: INTERRUPT CONTROL REGISTER
R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 R/W-x
GIE PEIE T0IE INTE RBIE(1) T0IF(2) INTF RBIF
[B]bit 7 bit 0
Legend:[/B]
R = Readable bit W = Writable bit U = Unimplemented bit, read as ‘0’
-n = Value at POR ‘1’ = Bit is set ‘0’ = Bit is cleared x = Bit is unknown
[B]bit 7 GIE: Global Interrupt Enable bit[/B]
1 = Enables all unmasked interrupts
0 = Disables all interrupts
[B]bit 6 PEIE: Peripheral Interrupt Enable bit[/B]
1 = Enables all unmasked peripheral interrupts
0 = Disables all peripheral interrupts
[B]bit 5 T0IE: Timer0 Overflow Interrupt Enable bit[/B]
1 = Enables the Timer0 interrupt
0 = Disables the Timer0 interrupt
[B]bit 4 INTE: INT External Interrupt Enable bit[/B]
1 = Enables the INT external interrupt
0 = Disables the INT external interrupt
[B]bit 3 RBIE: PORTB Change Interrupt Enable bit(1)[/B]
1 = Enables the PORTB change interrupt
0 = Disables the PORTB change interrupt
[B]bit 2 T0IF: Timer0 Overflow Interrupt Flag bit(2)[/B]
1 = TMR0 register has overflowed (must be cleared in software)
0 = TMR0 register did not overflow
[B]bit 1 INTF: INT External Interrupt Flag bit[/B]
1 = The INT external interrupt occurred (must be cleared in software)
0 = The INT external interrupt did not occur
[B]bit 0 RBIF: PORTB Change Interrupt Flag bit[/B]
1 = When at least one of the PORTB general purpose I/O pins changed state (must be cleared in
software)
0 = None of the PORTB general purpose I/O pins have changed state
I am trying to use the button to interrupt to pick a random value from the below code.
I am using INTE and INTF for the registers.
DieNumSel:
bcf INTCON,0
goto DieNumSel
movf temp1,w
swapf temp1,w
andlw b'00000111'
call Tabledie2
movwf die2
btfsc die2,7
goto DieNumSel
addwf die1,w
movwf PORTD
goto $
retfie
Tabledie1:
retlw b'10000000'
retlw b'00000001'
retlw b'00000010'
retlw b'00000011'
retlw b'00000100'
retlw b'00000101'
retlw b'00000110'
retlw b'10000111'
Tabledie2:
retlw b'10000000'
retlw b'00000001'
retlw b'00000010'
retlw b'00000011'
retlw b'00000100'
retlw b'00000101'
retlw b'00000110'
retlw b'10000111'
ExitISR:
movwf STATUS
swapf W_Save,w
retfie
This is above the label DieNumSel from the previous post.
ISR:
movf STATUS,w
movwf STATUS_Save
btfsc INTCON,INTF
goto DieNumSel
goto ExitISR
You are checking the wrong thing i assume you want to check RBIF or INTF Since those are the flag bits... also you have to clear the bit before you can check for another interrupt..
This code is confusing as that all you do is run the INIT then program ends
Try:
Start:
	call Init
WaitForInt:
     goto WaitForInt
end
The above code makes this program loop forever hence it will run without leaving maybe that was your main issue here tho..
This is all i thik i can help you with . You can still ask other and i hope they help you out.
FINAL
	cblock 0x20
	Delay2
	Direction
	LookingFor
	temp1
	die1
	temp2
	die2
	endc
	cblock 0x70
	W_Save
	STATUS_Save
	endc
org 0x00
goto Start
goto ISR
Init:
	bsf IOCB,0
	movlw 0x01
	movlw b'10010000'
	movwf INTCON
	movlw b'00000111'
	return
ISR:
        movf STATUS,w
        movwf STATUS_Save
        btfsc INTCON,INTF
        goto DieNumSel
        goto ExitISR
DieNumSel:
	goto DieNumSel
	movf temp1,w
	swapf temp1,w
	andlw b'00000111'
	call Tabledie2
	movwf die2
	btfsc die2,7
	goto DieNumSel
	;swapf die2
	;movf die1,w
	addwf die1,w
	movwf PORTD
	goto $
Tabledie1:
	retlw b'10000000'
	retlw b'00000001'
	retlw b'00000010'
	retlw b'00000011'
	retlw b'00000100'
	retlw b'00000101'
	retlw b'00000110'
	retlw b'10000111'
Tabledie2:
	retlw b'10000000'
	retlw b'00000001'
	retlw b'00000010'
	retlw b'00000011'
	retlw b'00000100'
	retlw b'00000101'
	retlw b'00000110'
	retlw b'10000111'
ExitISR:
	movwf STATUS
	swapf W_Save,w
	retfie
Start:
	call Init
WaitForInt:
     goto WaitForInt
end
This is sample ASM from MPLAB
;   This file is a basic code template for assembly code generation   *
;   on the PIC16F887. This file contains the basic code               *
;   building blocks to build upon.                                    *
;   Refer to the MPASM User's Guide for additional information on     *
;   features of the assembler (Document DS33014).                     *
;   Refer to the respective PIC data sheet for additional             *
;   information on the instruction set.                               *
;    Filename:	    xxx.asm                                           *
;    Date:                                                            *
;    File Version:                                                    *
;    Author:                                                          *
;    Company:                                                         *
;    Files Required: P16F887.INC                                      *
;    Notes:                                                           *
	list		p=16f887	; list directive to define processor
	#include	<p16f887.inc>	; processor specific variable definitions
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The labels following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
	__CONFIG    _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
	__CONFIG    _CONFIG2, _WRT_OFF & _BOR21V
;***** VARIABLE DEFINITIONS
w_temp		EQU	0x7D		; variable used for context saving
status_temp	EQU	0x7E		; variable used for context saving
pclath_temp	EQU	0x7F		; variable used for context saving
	ORG     0x000             ; processor reset vector
	nop
  	goto    main              ; go to beginning of program
	ORG     0x004             ; interrupt vector location
	movwf   w_temp            ; save off current W register contents
	movf	STATUS,w          ; move status register into W register
	movwf	status_temp       ; save off contents of STATUS register
	movf	PCLATH,w	  ; move pclath register into w register
	movwf	pclath_temp	  ; save off contents of PCLATH register
; isr code can go here or be located as a call subroutine elsewhere
	movf	pclath_temp,w	  ; retrieve copy of PCLATH register
	movwf	PCLATH		  ; restore pre-isr PCLATH register contents
	movf    status_temp,w     ; retrieve copy of STATUS register
	movwf	STATUS            ; restore pre-isr STATUS register contents
	swapf   w_temp,f
	swapf   w_temp,w          ; restore pre-isr W register contents
	retfie                    ; return from interrupt
main
; remaining code goes here
; example of preloading EEPROM locations
	ORG	0x2100
	DE	5, 4, 3, 2, 1
	END                       ; directive 'end of program'
I set the GIE,INTE and I am checking the INTF. There is more code than Init but it relates to rotating leds around the 16f887 board. I will keep looking at it.
thanks
Thats the thing you dont have to check the INTF if you get to the point that your checking it its because its set. That flag is there to tell the uC that a interrupt has occured all you have to do is clear it. If its ever set it will jump to the ISR code. So what you should do is remove that check frmo the ISR like this:
ISR:
[B]        BCF   INTCON,INTF                       ; Clear the Flag so new interrupts can be handled[/B]
        movf STATUS,w
        movwf STATUS_Save
DieNumSel: [B];Now this is in the ISR CODE without a jump[/B]
	goto DieNumSel
	movf temp1,w
	swapf temp1,w
	andlw b'00000111'
	call Tabledie2
	movwf die2
	btfsc die2,7
	goto DieNumSel
	;swapf die2
	;movf die1,w
	addwf die1,w
	movwf PORTD
	goto $
ExitISR:                                       [B] ; Again no jump needed[/B]
	movwf STATUS
	swapf W_Save,w
	retfie
Full Code
	cblock 0x20
	Delay2
	Direction
	LookingFor
	temp1
	die1
	temp2
	die2
	endc
	cblock 0x70
	W_Save
	STATUS_Save
	endc
org 0x00
goto Start
goto ISR
Init:
	bsf IOCB,0
	movlw 0x01
	movlw b'10010000'
	movwf INTCON
	movlw b'00000111'
	return
ISR:
        movf STATUS,w
        movwf STATUS_Save
DieNumSel:
	goto DieNumSel
	movf temp1,w
	swapf temp1,w
	andlw b'00000111'
	call Tabledie2
	movwf die2
	btfsc die2,7
	goto DieNumSel
	;swapf die2
	;movf die1,w
	addwf die1,w
	movwf PORTD
	goto $
ExitISR:                                        ; Exit right after the end of your jump code
	movwf STATUS
	swapf W_Save,w
	retfie
Tabledie1:
	retlw b'10000000'
	retlw b'00000001'
	retlw b'00000010'
	retlw b'00000011'
	retlw b'00000100'
	retlw b'00000101'
	retlw b'00000110'
	retlw b'10000111'
Tabledie2:
	retlw b'10000000'
	retlw b'00000001'
	retlw b'00000010'
	retlw b'00000011'
	retlw b'00000100'
	retlw b'00000101'
	retlw b'00000110'
	retlw b'10000111'
Start:
	call Init
WaitForInt:
     goto WaitForInt                           ; wait for interrupt in loop
end
OK 1 question
Are you trying to pick a radom value from the table?
If so why dont you just make a loop that increases a value in the WREG and when a interrupt occurs then put the value into a variable and at the end of the loop or in the ISR have it goto the specific location in the table by adding that value to the PCL.
Ill try to make you a example
hope you can understand this its like 11pm here and ive been up since 5am so hope im not going nuts :D
	__CONFIG    _CONFIG1, _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUT
    cblock     0x20
	Delay2
	Direction
	LookingFor
	temp1
	die1
	temp2
	die2
    endc
    cblock      0x70
	W_Save
	STATUS_Save
	MyVar
	MyVar2
    endc
    org 0x00
    goto Start
    goto ISR
Init:
     bsf    IOCB,0
     movlw     0x01
     movlw     b'10011000'
     movwf     INTCON
     bcf    STATUS,RP0
     bsf    STATUS,RP0
     movlw     b'00000111'
     return
ISR:
	movf      STATUS,w
	movwf     STATUS_Save
	bcf       INTCON,INTF
DieNumSel:
	bcf     INTCON,0
	btfsc	MyVar, 0
	btfsc	MyVar2, 0
	call	Tabledie2
	NOP
	movwf   PORTD
ExitISR:
	movwf     STATUS
	swapf     W_Save,w
	retfie
Tabledie1:
	MOVF 	MyVar, 0
	retlw	b'10000000'
	retlw	b'00000001'
	retlw	b'00000010'
	retlw	b'00000011'
	retlw	b'00000100'
	retlw	b'00000101'
	retlw	b'00000110'
	retlw	b'10000111'
Tabledie2:
	MOVF 	MyVar2, 0
	retlw	b'10000000'
	retlw	b'00000001'
	retlw	b'00000010'
	retlw	b'00000011'
	retlw	b'00000100'
	retlw	b'00000101'
	retlw	b'00000110'
	retlw	b'10000111'
Start:
    call Init
	movlw 0x00
	movwf MyVar
	movwf MyVar2
rotate:
     bsf       STATUS,RP0     ; select Register Bank 1
     clrf      TRISD          ; make IO PortD all output
     movlw     0xDF
     movwf     Display
MainLoop:
     movf      Display,w      ; Copy the display to the LEDs
     movwf     PORTD
OndelayLoop:
     decfsz    Delay1,f       ; Waste time.
     goto      OndelayLoop    ; The Inner loop takes 3 instructions per loop * 256 loopss = 768 instructions
     decfsz    Delay2,f       ; The outer loop takes and additional 3 instructions per lap * 256 loops
     goto      OndelayLoop    ; (768+3) * 256 = 197376 instructions / 1M instructions per second = 0.197 sec.
                              ; call it two-tenths of a second.
     bcf       STATUS,C       ; ensure the carry bit is clear
     rrf       Display,f
     btfsc     STATUS,C       ; Did the bit rotate into the carry?
     bsf       Display,7      ; yes, put it into bit 7.
	INCF MyVar
	;add delay
	INCF MyVar
	;add delay
	INCF MyVar
	;add delay
	INCF MyVar
	;add delay
	INCF MyVar
	;add delay
	INCF MyVar
	;add delay
	INCF MyVar
	;add delay
	INCF MyVar
	;add delay
	movlw 0x00
	movwf MyVar
	INCF MyVar2
	;add delay
	INCF MyVar2
	;add delay
	INCF MyVar2
	;add delay
	INCF MyVar2
	;add delay
	INCF MyVar2
	;add delay
	INCF MyVar2
	;add delay
	INCF MyVar2
	;add delay
	INCF MyVar2
	;add delay
	movlw 0x00
	movwf MyVar2
    goto MainLoop
	 end
Thanks for all your help. I dont have my computer with me but I will give it a shot this afternoon. I am trying to pick a random number.
