interrupt programming doubt
#include   <pic.h>
void main(void)
	int tmp;
	TRISB   = 0b00000000;
	RBPU = 0;      // Use internal pullups
	T0IE = 1;      // Enable interrupt on TMR0 overflow
	INTEDG = 1;      // falling edge trigger the interrupt
	INTE = 1;      // enable the external interrupt
   	GIE = 1;      // Global interrupt enable
	tmp=1;
   	for(;;)
      	CLRWDT();   // Idly kick the dog
	static void interrupt
	isr(void)         // Here be interrupt function - the name is unimportant.
   if(T0IF==1)
	if(tmp==1)
	PORTD=map[i];
	RB3=1;
	T0IF=0;
else if(tmp==2)
	PORTD=map[i];
	RB3=0;
	RB2=1;
	T0IF=0;
else if(tmp==4)
	PORTD=map[i];
	RB2=0;
	RB1=1;
	T0IF=0;
else if(tmp==8)
	PORTD=map[i];
	RB1=0;
	RB0,1;
	T0IF=0;
tmp=0;
tmp=1;
here i am trying do make a multiplexed display in intrpt.but while compling i am getting somany error.i dont knw to use intrpt an d i dont whethr the program is correct or not.
This will now compile without errors but it doesn't make much sense.
#include   <pic.h>
int tmp;        //was local to main
char map[4];    //wasn't defined
char i;         //ditto
void main(void)
	TRISB   = 0b00000000;
	tmp=1;
   	for(;;){
    if(T0IF==1)
	    if(tmp==1)
    	    PORTD=map[i];
        	RB3=1;
    	    T0IF=0;
        else if(tmp==2)
    	    PORTD=map[i];
    	    RB3=0;
    	    RB2=1;
    	    T0IF=0;
        else if(tmp==4)
         	PORTD=map[i];
          	RB2=0;
           	RB1=1;
           	T0IF=0;
        else if(tmp==8)
        	PORTD=map[i];
        	RB1=0;
        	RB0,1;
        	T0IF=0;
        tmp=0;
        tmp=1;
That depends on the hardware. It looks like you need to get a better understanding of how the software should work with the hardware.
this is my kit manual.but i dont get u about the intialization of map[] and i.how they related to my hardware?
  • arrangedMicromas&#116.pdf
I have been working with Jimmy. The map[] array maps each of the digits 0..9 to PORTD bits needed to turn on the 7 segment segments A..G. PORT RB is used to drive transistors connected to the common cathode of each digit.
He was close to having this working when he added the interrupt.
Jimmy knows ASM but has great difficulty with C.
I had a bit of spare time today and had a play with this. I think the following should display 1234 on the display.
#include   <pic.h>
int tmp;
char i[4]={1,2,3,4};
const char map[10]={
    0x3f,0x06,0x5b,0x4f,0x66,
    0x6d,0x7d,0x07,0x7f,0x67};
void main(void)
    OPTION=0b01000110;  //prescaler 128
    TRISB=0b00000000;
    TRISD=0b00000000;   //port D output
    tmp=1;
    while(1){       //loop forever
    if(T0IF==1)
        PORTB&=0xf0;        //turn off all segments
        T0IF=0;             //clear interrupt
        if(tmp==1)          //first digit
            PORTD=map[i[0]];//put segment pattern on port D
            RB0=1;          //and turn on display 1
        else if(tmp==2)
            PORTD=map[i[1]];
            RB1=1;
        else if(tmp==3)
            PORTD=map[i[2]];
            RB2=1;
        else if(tmp==4)
            PORTD=map[i[3]];
            RB3,1;
        tmp++;          //change to next digit
        if(tmp==5)      //done last digit
            tmp=1;      //yes so start again
To change the digits on the display you would do i[digitnumber]=digit. So, i[2]=7; would set the third digit to 7.
Note, this is untried as I don't have the hardware but it's fairly simple to follow.
When you change from digit to digit, turn off the common pin on the previous digit. If you do not you can get unwanted segments illuminated. I call this ghosting but it may not be the correct use of the term
turn off all common
select segments
select common
turn off all common
select segments
select common
If it's still flickering then reduce the prescaler even lower. I can't see any reason why the 4 wouldn't show up, check all the jumpers are correct on the board.
When you change from digit to digit, turn off the common pin on the previous digit. ....
I turned of all digits at the beginning of the ISR.
    if(T0IF==1)
        [COLOR="red"]PORTB&=0xf0;[/COLOR]        //turn off all segments
turn off all common
select segments
select common
turn off all common
select segments
select common
#include   <pic.h>
int tmp;
void main(void)
    TRISB=0b00000000;
	TRISC=0x00;
	RC0=0;
    tmp=1;
    if(T0IF==1)
			PORTB=0x00;
        else if(tmp==2)
            PORTD=map[i[1]];
			PORTB=0x00;
            RB1=1;
        else if(tmp==3)
            PORTD=map[i[2]];
			PORTB=0x00;
            RB2=1;
        else if(tmp==4)
            PORTD=map[i[3]];
			PORTB=0x00;
            RB3,1;
			PORTB=0x00;
but only 1 is displaying rest all othrs are in off condition
I was not suggesting there was a problem with your code. Just trying to help Jimmy understand what needs to happen. But given that you have written the code for him I will step back and shut up. :)
#include <pic.h>
int tmp;
void main(void)
TRISB=0b00000000;
TRISC=0x00;
RC0=0;
tmp=1;
if(T0IF==1)
PORTB=0x00;
else if(tmp==2)
PORTD=map[i[1]];
PORTB=0x00;
RB1=1;
else if(tmp==3)
PORTD=map[i[2]];
PORTB=0x00;
RB2=1;
else if(tmp==4)
PORTD=map[i[3]];
PORTB=0x00;
RB3=1;
PORTB=0x00;
now it is working......
