interupt problem with a 16f84a
gibbon_82
i am a student currently studying electronic engineering. for part of my project i have to program a 16f84a. i have read that with the 16f84, b0 is the only pin that can be used to perform an interupt. unfortunatly with the pcb that i have designed i would have to use pin a2. can this be done with the 16f84a, or will i have to rewire the pcb inorder to use pin b0?
any information that can help me will be very helpful.
thanks for your time
Craig.
The possible interrupt sources are listed on the very first page of the datasheet - RB0 is one, as are RB4, 5, 6 and 7 as 'Interrupt on Change'.
You can't use A2 to generate an interrupt.
Do you actually need to use an interrupt?, you can do a great deal without using them.
