Hi does anyone have any suggestions for replacing an IP323T-15 voltage regulator? I have accidently broken one of the legs while adding a new heatsink and need to swap the part out.
It has a 3A output..
Data Sheet Spec.
IP323T15
Fixed Positive Voltage Regulator
Integrated Power Semiconductors
Output Voltage Nominal (V)=15
Load Current Max. (A)=3.0
Tolerance (%)=1.0
Drop-Out Volt Max.=2.9
P(D) Max.(W) Power Dissipation=25
Supply Voltage Maximum (V)=25
Status=Discontinued
Package=TO-220
Pins=3
Military=N
Data Sheet Spec.
IP323T15
Tolerance (%)=1.0
Status=Discontinued
Package=TO-220
Pins=3
Military=N
