Mosaic
Hi All:
Just installed an IPTV domestic service BUT it ONLY transmits on electrical outlets (120V) which are on the same 120V leg. My home is supplied with two 120V phases to produce 240V for heavy appliances as required. The house wiring has no apparent pattern of which 120V 'hot' is used in the 120V outlets.
My question: is there a device that allows me to bridge the IPTV signal into the second 120V leg. Perhaps via a 240VAC outlet? If not, can I make such a filter that permits IPTV but not the line voltage?
My IPTV providers solution, is to use a 120V extension cord routed to a 120V outlet that is on the IPTV 'hot' to supply the presently disconnected TV. That sucks.
