Hi I realise that this thread is a bit old, but on the 25June 2011 post no 28 Eric Gibbs posted a circuit, and I want to know if I need permission to use it? If I have permission to use the circuit I will post mine for your comments and advice.
jada88
Hi Eric
I think the circuit is a break beam. It is in connection with another post I did about a bathroom mirror IR failure. How do I switch on the SSR?
Hi Eric
Thanks for your advice. Yes when you place your hand in front of the sensor the light is activated. I have spent a lot of time on line trying to find a circuit so I can make a pcb to replace the original unit. Not very happy with a transformerless unit. Perhaps you can point me in the right direction.
Hi Eric
Thanks for the circuit. I take it that it uses a photo-diode for sensing, could I still use the OPB702, if not what photo-diode would you recommend? Would a C106D Thyristor be suitable to use in this circuit for the SCR? In the circuit it has LIGHT R11 1000 is this the load (1000W).
Hi Eric
The circuit only powers a LED converter 240VAC in 24VDC out 0.625A. Will the OPB702 work with this circuit.
To switch on the mirror led the distance was aprox 15 to 50mm from the front of mirror.
Hi Eric
Thank you for your advice and time, I will see if I can find the problem with the original PCB.
