I constructed an infra-red receiver using IR-sensor from TV, schmitt trigger-4093, monostable-555, flip-flop:4013, transistor and relay. I'm using this receiver to switch on/off a lamp. The problem with the circuit is that if i power it with a rectified voltage source, the lamp will start going on/off by itself (oscillation) but if i power it from a 9V battery source, the circuit behaves properly.
How can I modify the circuit so that I can power it with a rectified voltage source as the 9V battery gets drained within minutes.
