Do we believe that he has a system with that kind of gain and bandwidth? Or are the axes just mislabeled?speakerguy79 said:Too close for comfort IMO. You've got gain >1 and phase ~ -180 just shy of 100MHz. 5% tolereance here, 2% tolereance there, could blow up. Need bigger phase margin anwhere where gain >1 (0dB).
As for the red box, I dunno. Does the system really have that much bandwidth?
Papabravo said:I don't think so. Do you have some reason to suspect instability? A root locus diagram would answer the question difinitively. You might also try the Routh-Hurwitz criteria.
speakerguy79 said:As for the red box, I dunno. Does the system really have that much bandwidth?
What you say about the step function is true, but real components cannot respond to a step input in an ideal fashion. Real components have slewrate limitations and will saturate when the gain is large like 80 dB.FusionITR said:I'm talking theortetically.
As far as stablity goes, as far as I understand, if you apply an ideal step reponse with a feedback loop, you are essetically inputing a frequency of infinity, therefore if your system is unstable at any frenquency (even if its at 100Ghz) it will show.
Papabravo said:Probably not. Still 80 dB is 10 Volts from a millivolt input. You'll reach sturation long before sability becomes an issue. I would suspect that there is something wrong with the thing you are simulating. What is it by the way.
Papabravo said:How can you not AC couple the inputs? A millivolt of DC offset will peg the output with that much gain at DC. There is something wrong with this picture, but I'm no expert at IC design and those little parameters are meaningless to me. Perhaps the feedback impedance is large enough to effectively remove it from consideration.
Roff said:Wee, it has 20dB of gain with -300 degrees of phase shift, but it's an open loop circuit, so it shouldn't be unstable. Apply feedback and we have another ball game.
