A battery on float charge should be ok as the power source; but good filtering of the supply to the 4060 will still be necessary to reduce voltage spikes. Consider using a transient voltage suppressor plus capacitors across the supply, and chokes in line with the supply rails. Build the timer circuit on a pcb; not a breadboard. Use compact wiring and screened connections to the pcb. House the circuit in a screened enclosure.
