Can Anybody knows that following mentioned kit is available or not, if yes the with what exact name and from where?.........I shell be really grateful:
I want to buy a product (if exits) with following features.
My required features are as under:
1- If I rotate the knob of the "potentiometers" to 30 degrees clockwise then the drive shaft of the motor should also rotate 30 degrees clockwise and with same speed with which I will rotate the knob of "potentiometers".
2- If we rotate the "potentiometers" in any direction then the motor’s drive shaft should also move in both directions respectively.
3- Input current should not be less than 3.5amp. I mean to say that I need to pick-up & move almost 10 to13kg of weight with 40 to 400 rpm. So the motor should be that much heavy to accomplish the job easily.
4- This kit should have input of 12volts.
THANKS!
THANKS!
