Please take a look at my previous post's update .Is the frequency compensation set correctly on the X10 probe ?
When I saw that scope trace, my first reaction was - poor high frequency response.
You may need a load to see the output properly.and have no load eather
hi BGA,
My feeing is that you have a problem involving the potential of the earth of the CRO compared to the earth of the welder.
Not sure which welder we are talking about, but I mentioned in a post somewhere, that I use a pair of back to back isolating transformers to allow the CRO ground lead to sit on the power supply negative point.
The traffos I use are about 50 watts; you can short out the transformed secondary and the short circuit current is only a couple of hundred milliamp; BUT its enough to do the sort of thing you are trying to do. With the traffos, you wont need the series resistor.
You say you used 'pin 7', and called it an output. You might want to go back to the data sheet. On the 8pin version of the chip #7 is the Vcc of the chip. On the 14pin version #7 is the pin to control the freq/duty cycle, Rt/Ct.
Of course i will record a video and share it here .Sounds like progress.
Can you describe what you did to get a sensible looking waveform. maybe a picture of the result too?
