What crap is that: higher sampling rate with more channelsReal-time sampling: 75MS/s one channel, 150MS/s using two channels
Is that allVertical resolution: 8bits/channel
bitem2k said:Im a poor student!
I cant afford hundreds of £ for a 'proper' scope.
do you think it might be a reasonable first scope?
mcs51mc said:Did you read the specs?
Or it's always 75MS/s per channel
Or it's the other way 150MS/s one channel and 75MS/s two channels
and further
Is that all
Use a PIC and send serial data to the PC and you will have better results!!
ericgibbs said:hi bitem,
The spec looks fine, the 8bit [255 increments] Y axis is a little limited.
mcs51mc said:Check the NI Site they have (more or less) cheap USB DAQ pads!
Good, very good stuff...
mcs51mc said:Off topic : £ what England are you in??
follow up to hero's Q, what projects do you want to scope??
ericgibbs said:What's the spec of your PC?
They aren't disagreeing about the scpecs. They're saying different things about different parts of the specification.bitem2k said:You both seem to disagree about the specs.
Hero999 said:You appear to be getting stressed (this is indicated by your decision to use bold text), there's no need to get stressed, no one's arguing or having a go at you.
May I ask which town/county you are in?
Eric
HerbertMunch said:Canterbury, Kent
HerbertMunch said:
