Is this simplified flowchart describe my code?
imane tech
Hello Community !!
My project is about doing a simulation of a circuit in order to display a signal related to my pulse sensor. Actually, I'm not quite familiar with coding using the C++ language, I tried to make a flowchart that describes what is the code doing in general. So what Do you think? Did I neglect some important parts?
(I'm a newbie, so please just be patient!!)
What else can I provide to get some help?
  • HeartRateArduino-master.zip
Hi Imane
Firstly, it's not a good idea to have two threads running on the same topic .. likely the Mods will want to modify that .. .
Have I got this right ? You're trying to build a circuit to emit a dummy pulse to test your pulsemeter ?
What have you done so far ? Built the circuit ? Tried but failed ?
MM
You have made a historical invention. A decision point that has one "no" branch and two "Yes" branches. In this specific case, the "Yes" branch would do one chore and then the other:
A conventional approach is to have just two exits: "Yes" and "No". If the "Yes" branch can split again you would have a second test but you don't here.
In the "Yes" branch you would perform the two "Yes" tasks sequentially when using a single core processor.
1. Display the PPG signal in the plotter, and then
2. The LEDs will light up with the heartbeat
Or execute in reverse.
