I have a device that will trigger when it senses 3 (+) or (-) pulses in a row. When the device triggers it will output a (- 150ma) or (+) ( for 30 seconds )to roll down my windows and top or roll up my windows and top. This device has already been aquired and I needed to use it to interface with my factory remote ( for a car).
This is my problem. The trigger Im using is the wires off the lock.unlock motor
The motor shows these conditions
( wire 1 and wire 2 are the motor wires)
DURING LOCK
wire 1 is + ( around 7 VDC)
wire 2 is -
DURING UNLOCK
wire 1 is + ( about 5VDC)
wire 2 is +
Since IM using a positive trigger, when unlocking wire 1 will kick off the lock device ( roll up windows). I only want the device connected to wire 2 ( which is + during unlock) to kick off.
I thought abot killing power to the device on wire 1 using a relay but I really dont want to use a realy.
Is there any project I could build that when it senses wire 1 is + and wire 2 is - to activate a device? I.E. send power to the device
or when it senses wire 1 is + and wire 2 is + to kill power to a device?
or is there a device that on a constant + kill power to a device?
Thank for all your help. If you need additional information please ask
If you are using the remote to lock & unlock 3 times to trigger the device, you only need the signal on wire #2. I don't see any point in turning the device Off and On. The device should include a timeout so the window does not automatically roll down the third time you lock or unlock the car.
Your 'motor' voltage should be 12v. locking solenoids draw several amps and you're probably getting a voltage drop across the wiring. They lock/unlock by changing the polarity to get the opposite action. The output of your device has to be capable of handling 8-10 amps ,otherwise you'll need a relay interface. They are intermittant duty devices, not to have voltage on them continously...
It looks like the switch for the motor is on the negative side of the
supply (open collector). When in Off state, both ends are on same
(positive) potential.
heres a schmatic of the motor **broken link removed** . the first motor is referred to as the central locking motor the second one is the central locking (SAFE) motor.
