isis simulation problem
illias28
Hi every body,
can any one help me please, i want to simulate the Following schematic with pic 16f84a, a modulo 100 with displaying the results on tow 7 segments in multiplexed mode .but the simulation doesn't work.here you will find the schematic and the hex file.
and thank you very much
  • affmux.hex
  • affmux.c
What is the resource of your code? Is it complete?
I WROTE MY PROGRAM WITH MIKCROC .
ON MY BREADBOARD THE CIRCUIT IS WORKING GOOD BUT NOT IN THE SIMULATION WITH ISIS
Right! Simulation has to be treated carefully... You may have to edit the LED component to see anything... Whereas a real component may show dimly the ISIS component will have difficulty.. Try and change the duty cycle to see if it helps...
thank you very much ,Ian rogers for your help,
i found that the probleme was with the version of proteus, i have version 8.8 installed on my pc .
i tried the same simulation on a friend's pc who has proteus version 7.6 and it works good.
