Hello,
Just discovered these forums. Seems I've been missing out.
I've got a 12V to 5V buck conveter which I am to now convert to an isolated design. Obvious progression was a forward converter.
Using the TL5001 for PWM/Control and a P-Channel MOSFET (FQP17P06/7) with basic totem pole driver. 47uH ind/100uF cap.
Wound the transformer 4:2:4 (Primary
emag:Secondary), chucked another diode in on the secondary side but there's no output. Seems there is a short somewhere, as the short circuit protection on the TL5001 is high.
Is there any reason that a forward converter would not work with a P-Channel MOSFET?
I initially tried the converter with an N-Channel but switched to the P-Ch due to simpler gate drive circuitry. As I understand it the N-Ch needs Vin + Vgs(thresh) to switch the FET. True? How to overcome?
Is there a way I can drive the N-Ch without too much hassle?
For the isolated feedback I was going to go for an opto/431(programmable zener/shunt reg) combo. That's the best bet?
Any help/pointers to resources would be much appreciated![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers,
simon.
Cheers,
simon.
