From Hack-A-Day, an easy way to design laser-cut enclosures of many shapes and styles.
Boxes.py will generate the needed files for many styles of boxes, including those with flexible panels. Just enter the needed parameters and you'll get the files for a laser cutter. One of the interesting options are enclosures for 19" racks. An acrylic alternative to a commercial enclosure is nice for prototyping and checking dimensions before committing to machining.
If you don't have a laser-cutter, no problem. Many hacker spaces will cut laser projects for you, and commercial services are getting common.
Boxes.py Has Your Lasercut Box Needs Covered
I needed something to test out a low-power laser cutter, and thought that some small cardboard boxes would fit the bill nicely, so off I went to scour the Interwebs for a quick-and-dirty finger-joi…
hackaday.com
