futz
Active Member
I've got INT0 working fine to detect Switch 1. But when I make the changes to use INT2 to detect Switch 2, all that happens when I press the button is the program crashes and I have to reset. INT0 still works.
Here's the code:
Here's the code:
list p=18F1320
include <p18f1320.inc>
CONFIG OSC=INTIO2,WDT=OFF,MCLRE=ON,LVP=OFF,DEBUG=ON
cblock 0x00
d1
d2
d3
seqnum
endc
org 0x0000
goto init
org 0x0008 ;Interrupt Service Routine
isr1 tstfsz INTCON,INT0IF ;is it INT0?
goto int0 ;yes, go handle it
int2 nop ;no, handle the INT2 interrupt
nop ;nop's are temporary
bcf INTCON3,INT2IF
retfie FAST
int0 incf seqnum ;switches to next LED sequence
movlw 3 ;is seqnum 3?
cpfslt seqnum ;skip if seqnum < 3
clrf seqnum ;seqnum = 3, clear it
bcf INTCON,INT0IF ;clear INT0 flag
retfie FAST
init bsf OSCCON,IRCF2 ;set to 8MHz clock
bsf OSCCON,IRCF1
bsf OSCCON,IRCF0
movlw 0x7f ;set PortA to all digital
movwf ADCON1
clrf TRISA ;set PortA pins to output
movlw b'00100101' ;set PortB pins (switches = inputs)
movwf TRISB
clrf LATA ;turn off all LEDs
clrf seqnum ;set seqnum=0
clrf INTCON2 ;enable weak pull-ups and falling edges
movlw b'10010000' ;enable INT2 interrupt
movwf INTCON3
bcf RCON,IPEN ;disable irq priority levels
movlw b'10010000' ;enable interrupts (INT0)
movwf INTCON
Main movlw 0 ;calls correct LED sequence
cpfseq seqnum ;according to seqnum value
goto next1
call seq1
next1 movlw 1
cpfseq seqnum
goto next2
call seq2
next2 movlw 2
cpfseq seqnum
goto next3
call seq3
next3 goto Main
; bcf OSCCON,IDLEN ;Run mode enabled
; bcf OSCCON,SCS1 ;Primary oscillator
; bcf OSCCON,SCS0
; sleep
seq1 call led6 ;descending LEDs
call led5
call led4
call led3
call led2
call led1
return
seq2 call led1 ;ascending LEDs
call led2
call led3
call led4
call led5
call led6
return
seq3 call led1 ;pairs of LEDs
call led2
call led6
call led5
call led3
call led4
return
led1 bsf LATA,RA0 ;blinks led1
bcf LATA,RA6
bsf TRISA,7
call Delay
call alloff
return
led2 bcf LATA,RA0 ;blinks led2
bsf LATA,RA6
bsf TRISA,7
call Delay
call alloff
return
led3 bsf TRISA,0 ;blinks led3
bsf LATA,RA6
bcf LATA,RA7
call Delay
call alloff
return
led4 bsf TRISA,0 ;blinks led4
bcf LATA,RA6
bsf LATA,RA7
call Delay
call alloff
return
led5 bcf LATA,0 ;blinks led5
bsf TRISA,6
bsf LATA,RA7
call Delay
call alloff
return
led6 bsf LATA,0 ;blinks led6
bsf TRISA,6
bcf LATA,RA7
call Delay
call alloff
return
alloff clrf TRISA ;all leds off
clrf LATA
return
Delay movlw 0x01
movwf d1
movlw 0x7f
movwf d2
movlw 0x01
movwf d3
Delay_0 decfsz d1,f
goto $+6
decfsz d2,f
goto $+6
decfsz d3,f
goto Delay_0
return
end
