Hi all, newbie![angelic :angelic: :angelic:](/styles/default/xenforo/smilies/angelic.png)
I'm repairing a keyboard at the minute, it's a Roland GW7 if anyone's interested in instruments.
It's in two parts with the back light and the screen which is connected via a very thin cable as shown in the photo's.
I found that if I run my finger over this cable the screen will come on. So I heated it up a bit which actually fixed it!!
problem being that it only lasted about a hour before coming less tight and going off again.
(when I say going off I mean the actual text the back light is fine)
I've never seen this type of cable/film before, does this have some name?
What's basically wrong is that the glue holding the cable to the back of the board has come loose, hence me heating it to try and make it re-stick.
Does anyone have any idea's on how to fix this? can it be re-glued or can you buy this stuff and cut it to size?
**broken link removed** **broken link removed**
Just to add, that front bit comes away from the back but is connected by the flex cable
