S spuffock Member Oct 5, 2005 #1 Anyone know a rough correlation between the weight of a 50 hz toroidal transformer and its power handling capacity? I've got some 24 volt ones, weigh 2kg. I thought I might try 10A, see how hot it gets.
eblc1388 Active Member Oct 5, 2005 #2 You're pretty close in your current estimate. From the information here: **broken link removed** Or here: Theoretical Size, Weight, and No-load Losses for Toroidal Power Transformers The estimated power rating of a 2Kg(4.4lb) toroidal transformer will be about 200VA to 220VA.
