Willen
I have a long and 1.8 cm diameter aluminium pipe. Actually it is a Boom of Yagi Uda. I want to use it as a straight Dipole antenna rod. But it has large diameter of 1.8 cm. If I use it on my 100MHz FM Tx, will it be perfect radiator?
I will cut these rod in exact length by calculating the formula of dipole rod length including A or K (diameter of rod) factor. (do you have any simple formula for A/K factor?)
