Finally fitted the last of 100 7 pin Amphenol Mil. Spec. plugs ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Just got the other ends to do now![arghh :arghh: :arghh:](/styles/default/xenforo/smilies/arghh.png)
Actually the pins are 'numbered' A to GAre you sure pins 1 and 4 are not to be transposed ?![]()
Been there, done that.Remember to slide the backshell on the cable before soldering! Nothing worse tthen noticing the backshell off to the side after you just finished soldering all the contacts.
If you look at the pictures in post #1, you will see all the back shells and heat shrink slid on the partly built cables, ready for fitting the final connectorsRemember to slide the backshell on the cable before soldering! Nothing worse then noticing the backshell off to the side after you just finished soldering all the contacts.
