LCD display C program
Parth86
Hello everyone
here is code which display message " ELECTRO-TECH" on screen
C:
// Program for LCD Interfacing with 8051 Microcontroller
#include<reg51.h>
#define display_port P1      //Data pins connected to port 2 on microcontroller
sbit rs = P2^0;  //RS pin connected to pin 2 of port 3
sbit rw = P2^1;  // RW pin connected to pin 3 of port 3
sbit e =  P2^2;  //E pin connected to pin 4 of port 3
void msdelay(unsigned int time)  // Function for creating delay in milliseconds.
    unsigned i,j ;
    for(i=0;i<time;i++)
    for(j=0;j<1275;j++);
void lcd_cmd(unsigned char command)  //Function to send command instruction to LCD
    display_port = command;
    rs= 0;
    rw=0;
    e=1;
    msdelay(1);
    e=0;
void lcd_data(unsigned char disp_data)  //Function to send display data to LCD
    display_port = disp_data;
    rs= 1;
    rw=0;
    e=1;
    msdelay(1);
    e=0;
 void lcd_init()    //Function to prepare the LCD  and get it ready
    lcd_cmd(0x38);  // for using 2 lines and 5X7 matrix of LCD
    msdelay(10);
    lcd_cmd(0x0F);  // turn display ON, cursor blinking
    msdelay(10);
    lcd_cmd(0x01);  //clear screen
    msdelay(10);
    lcd_cmd(0x81);  // bring cursor to position 1 of line 1
    msdelay(10);
void main()
    unsigned char a[15]="ELECTRO-TECH";    //string of 14 characters with a null terminator.
    int l=0;
    lcd_init();
    while(a[l] != '\0') // searching the null terminator in the sentence
        lcd_data(a[l]);
        l++;
        msdelay(50);
I show message with cursor. when message display I don't want to see the cursor in message. Is it possible ? how to do it ?
Change,
to
lcd_cmd(0x0d); // turn display ON, cursor OFF
For an explanation see attached datasheet.
  • LCD Module data sheet.pdf
Change,
to
Thanks. Now I don't see the cursor but I see the black symbol at the starting of every characters. what is that? Is it cursor position. I am trying to see message without black symbol.
Try changing it to 0xc0. Not at computer at moment so might be wrong.
Change this.
to this..
unsigned char a[15]={"ELECTRO-TECH",0};
And change this..
to this..
lcd_cmd(0x0C); // turn display ON, cursor blinking
thanks. now it works just two changes
I thought that double quotes always created a null terminated string. What compiler is this? Is there some rule for when no null is added?
Not so much the double quotes... The curly brackets were missing..
