Hi
I would like to use this LCD in a project due to its small size, and the RGB backlight.
https://www.electro-tech-online.com/custompdfs/2011/02/0900766b80bf5315.pdf
I know what to do with the data pins D0-D7 and also CS1,RST,A0,WR,RD. These all go to my PIC.
The other pins, VOUT,CAP3P,CAP1N, Etc, and also pins V0-V4 i dont know what to do with them, i have found info on these being for power settings but i dont know how to connect them all up. I know they have to have capacitors connected to them but i dont know what values or what goes to what.
C86 i think is for setting wether it runs in serial or parallel mode, again from what i read C86 goes low for parallel.
P/S again not sure on.
Has anyone worked with this LCD before or anything like it?
Can anyone help me to make a full circuit for the LCD?
Also, looking at the datasheet it says that this LCD requires 9v Supply voltage, can someone confirm this as normally there only 3.3v or 5v
